Page 1 of 3 123 LastLast
Results 1 to 25 of 58
    Danbury Connecticut
    Default What's the extra Switch on the 2020 RT Limited for?
    Does anyone know what the extra switch is for on the RT Limited panel. I've got switches for the seat heaters, grip heaters, and the windshield.
    There's one extra switch. I thought it was for the auxiliary light on the front, but I'm told that it's not. What else could it be ?
    It's just a blank switch cover.
    I know I'm being anal.
    I may come up with some kind of graphic to install on it that says "spare".
    IBA #47122
    2020 RT Limited Asphalt Grey
    Bossier LoUiSiAna
    Nothing in manual
    Aug 2019
    Illinois
    Page 21 of the on line owners operators guide manual says it is for an “accessory light”.
    http://www.operatorsguides.brp.com/O...0/620072EN.pdf
    Danbury Connecticut
    Quote Originally Posted by Breedog View Post
    I hear you, but I just checked with the dealer, they'll be installing my auxiliary light next week and there's no switch in the kit.
    IBA #47122
    May 2017
    Mesa, Arid-Zone-A
    CanAm calls it an accessory light switch and you say your dealer is installing an auxiliary light kit. May be two different things. The accessory light switch has low, high, and off positions. Sounds to me like your dealer may be installing an after market auxiliary light.....? Or perhaps the switch is "sold separately"..... Jim
    Semper Fi
    Active Member RTL1330's Avatar
    Dec 2014
    Campbell River, BC, Canada
    The extra switch slot is for the front lower accessory LED light. When the light kit supplied you pop out front lower cover. It has a plug on back, remove plug and connect it to LED lamp bar and install lamp. Pop out the blank switch cover on dash, it has plug on back of it. Connect plug on to supplied switch assembly in kit. Snap ne w switch into dash. It's a DIY install by BRP.
    Terry.
    2020 RTL - Petrol Blue Metalic / Black, dark model.
    Colour match rear tail cover, Garmin GPS.
    Heated Ultra Comfort driver seat & backrest.
    LED headlamps, LED Front corner lamps and lower front LED lamp.
    Baja Ron sway bar.
    Ride Til You Rot!
    Nov 2018
    Claremore, Ok.
    It's for the optional "Ejection Seat".
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Jan 2020
    New York
    Quote Originally Posted by RTL1330 View Post
    The extra switch slot is for the front lower accessory LED light. When the light kit supplied you pop out front lower cover. It has a plug on back, remove plug and connect it to LED lamp bar and install lamp. Pop out the blanks with cove on dash, it has plug on back of it. Connect plug on to supplied switch assembly in kit. Snap ne w switch into dash. It's a DIY install by BRP.
    Terry.
    Ive installed the front auxiliary light and there is NO switch. Somewhere along the line they changed their mind and wired the light directly to the running lights. So for now, its just a blank with no apparent purpose.
    2020 RT Limited , ASPHALT GREY METALLIC - DARK EDITION
    Dec 2014
    Did you pop out the blank to see if front light wiring there? My dealer assured me of the front lower light being switched at the blank spot.
    They showed us an info sheet on front lower LED accessory lamp. My new Spyder just arriving in crate. I'll confirm with tech as I don't want it on all the time.
    Baja Ron sway bar.
    Ride Til You Rot!
    Is this the light you guys are referring to, the one at bottom? Part number 219400991. If so the installation instructions say nothing about a switch. It plugs into a connector behind the light. https://instructions.brp.com/content...mber=219400991
    Danbury Connecticut
    Yes, that is the light that I'm talking about. I'm having it installed next week. The dealer has assured me there is NO switch in the kit.
    I'm pretty anal. The blank switch located off center is driving me nuts. I think I'll put some graphic on it so it looks like it belongs.
    I guess I'm in touch with my inner "Monk".
    IBA #47122
    Sebring, FL
    Did you buy the light from BRP, or is it available from a vendor? I like it, probably gotta have it.
    Apr 2016
    Albany NY
    Haven't seen a aftermarket yet... somebody wiil do it. BRP light is crazy $$$ $225
    Danbury Connecticut
    I had the light installed, and yes it goes on and stays on with the ignition. There is no light switch.
    The blank on the console remains a blank. I had to put a little graphic on the blank switch to satisfy my OCD.
    IBA #47122
    Apr 2012
    Florida
    That is a BRP light. Retail is $250, which is nuts! Tom
    2020 Petrol Blue Metallic RTL
    Active Member mrwog's Avatar
    Aug 2009
    Effingham NH.
    The light to be installed in the front lower section runs when you turn the Spyder on. when you pop the front plate to put the accessory light in the plug for the light is attached to the space filler plate. you simply unplug and plug into the new light and screw it in with the 4 supplied screws. Takes about 10 minutes or less.
    Some people are like Slinkies good for nothing but fun when tossed down the stairs
    Aug 2009
    Effingham NH.
    Terry.
    Mine had no plug it was an empty hole. so mine runs all the time the bike is on. no switch for that hole was supplied with the kit
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by Tango View Post
    Everything BRP offers for these machines is expensive. If you want it you pay the $$$. It is what it is.
    2020 RT Limited , Chalk
    Jan 2011
    Windsor, CA
    I'm going to wire by American LED flag into that position so I can operate it when I chose and that' keeps the LEO in CA from pulling me over about having a blue light to the rear.
    Sebring, FL
    RedLight, that sounds like a good plan.
    Apr 2020
    California
    No switch. It’s always on when bike is on.
    15F9BC83-F6FD-40DE-84B1-DA8362103694.jpg 08601507-5EE5-4C0E-BA45-7099AFCE1C7F.jpg
    4 screw installation and always on.
    Member MM20SPY's Avatar
    Apr 2020
    United Kingdom
    At least you guys have the connection behind the plate, in the uk we don't even get that!
    Feb 2016
    I installed the front aux light in mine. The connector was right behind the plastic blank panel. No switch is needed or used for this light. It is on anytime the headlights are on. That said, I needed to power two aux circuits. One for my Sirius radio and the other for my garage door opener. I had to make a wiring harness and obtain the correct style and type of switch (Off - On - Momentary) to make it work. I've wired it so the red led light in the switch is only on when the switch is in the ON position, not all the time.
    2020 RT Limited , Marsala Red
    Jun 2020
    Seaford, Delaware
    Just had the bumper light installed switch is not used for that. I’m thinking it’s for accent lights etc
    2020 RTL , Petrol Metallic
    Jun 2010
    Las Vegas
    Very nice! I have two blanks but I had heat added to my new seat so I will run it to one switch and I like the garage door idea. Does it work if the key is not on? Sometimes I leave the bike out if we are working on something and wouldn’t want someone to hit the button and open the garage.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
