Page 1 of 3 123 LastLast
Results 1 to 25 of 62
    Default Canister-Ectomy - 2008-2016 SM5/SE5
    Every so often I get questioned about doing a Canister-Ectomy on the V-Twin, 998cc versions of the Spyder. So I thought I'd detail it here in the hopes that it will help someone. This process removes both the Fuel Vapor Canister and the problematic Purge Valve (one is remove, the other incapacitated.
    While the Evap-Fuel Vapor Canister issues were more prominent on the earlier models. 2008-2012, this general procedure will also work on the later models. Done correctly, this will eliminate all fuel smells and the potential fire hazard that these present when not functioning properly. Plus, it will eliminate any issues with filling your fuel tank all the way to the top. This can give you up to 30+ miles extended range on your 998 Spyder, depending on how you are filling it now. There is a small triangle at the top of your fuel gauge. Most have never seen it because most have never actually filled their fuel tank. It is interesting that BRP has the 'Full Mark' on the gauge and then tells you not to fill it all the way up.
    Removing the vapor recovery canister system will also save you a little on maintenance costs.
    The diagram below is of the earlier 2008-2012 models. BRP made some minor modifications to this system on the 2013 and later models. But the major components are the same and the general Canister-Ectomy process applies. This is a simple and inexpensive modification.
    Referring to the diagram below. Once you remove the fuel vapor recovery canister located on the right side of the Spyder, behind the Tupperware (#21), you are left with 2 hoses, (#19 & #24). Hose #23 is just a vent to outside air and goes away with the canister.
    Taking care of Hose #24. This is your fuel tank vent hose, which is required. You need to route and zip tie this hose back along the right side frame to somewhere about mid rear fender. You want to route this vent hose (#3) upward from the fuel tank until it naturally begins to descend to the exit point. This will happen automatically if you follow the frame tube to the back. The existing hose is not long enough to get this far back so you will need to purchase an appropriately sized hose barb (Pictured Below) and another length of hose to extend it. These can be found at any auto parts or lawnmower shop. While you are there get a small fuel filter similar to the one pictured. I like the clear ones so you can see what is going on at the end of your vent hose, but virtually any version will do.
    Insert the fuel filter at the end of the fuel tank vent hose you've routed to the rear of your Spyder. Mount it horizontally as pictured. This will keep any foreign substance from entering the vent hose and will also serve to give you indication if any liquid fuel is being pushed through the vent hose as it will collect at the bottom of this filter. This will tell you if you have installed the vent hose correctly. You can clamp these fittings if you like. But it is not necessary. I did not clamp any of mine. A good tight fit is more than sufficient.
    Some have run this hose over the engine to the front of the Spyder, I am assuming with decent results. This may be a bit easier. However, I do not like the idea of running a fuel vapor hose over a hot engine to vent in front of the rider. If there are any fumes, or raw fuel, I would rather have it go out the back.
    Taking care of Hose #19. This hose connects to your purge valve, (#18) and then to the intake side of your engine via hose (#22). There are a number of ways you can deal with this. I've found it easiest to simply put an appropriately sized, 1/2 long or so, bolt with some silicone sealer into hose (#19) leaving the rest of the system in place. But whatever you do, you will need to seal this system so no air can enter, either before or after the Purge Valve (#18). I recommend simply leaving the purge valve in and plugging the hose on the intake side. Do not leave this hose open no matter which way you intend to complete this portion of the removal process.
    As always. You can hover you mouse pointer over a picture and it will enlarge for better detail.
    Oct 2015
    Lynden, WA
    Ron,
    Thanks for the clear and concise details.
    I have the parts and will be doing the canisterectomy
    along with my "Spring Service" later this week.
    Just needed a push to get me started.
    Cheers, David C.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Oct 2014
    Fort Mill, SC
    Default One more benefit
    My 2011 RTS developed a slight throttle surging when cruising. It wasn't serious, but very annoying. The Canisterectomy cured it 100%.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    If nothing else, doing this Canister-Ectomy will give you piece of mind. It will avoid any future issues and can solve some current problems. The smell is gone, the potential hazard is gone, and you can fill your fuel tank to the top without worry. Cheap, easy, and well worth the effort.
    Default Thanks .....
    Always good to have clear instructions for these changes. I know the question comes up from time to time and the twins are still out there....
    May 2014
    Beaverton, Oregon
    Hi Ron,
    Re: Canister-Ectomy - 2008-2016 SM5/SE5
    I just finished doing this to my '08 GS.
    Purge Valve Line)
    I simply cut it off right where it entered the canister. I took a 5/16” bolt, wrapped it with teflon tape as used in plumbing, ran the bolt in & secured with a worm drive clamp.
    I then secured it to the frame with two zip ties; in white in this photo:
    Fuel Filter)
    You will note in the above photo that I moved the line from the fuel tank upward so that the line is routed above where it goes into the fuel tank.
    In the lower left of the above photo is where I secured the fuel line to the frame. I use white zip ties whenever doing things like this as they are easy to see/find if I should need to remove them in the future.
    Here is the filter almost vertical:
    Line Routing)
    Here where I terminated it. It is turned down slightly so any gas should readily drip onto the ground.
    Jerry Baumchen
    PS) This is the fuel filter that I bought. It comes with various size fittings for different sizes of hose. I used 1/4” fittings & 1/4” hose. It is a Mr. Gasket product, #9706; bought at a local auto parts store:
    And by installing the filter directly into the line from the gas tank I did not need this:
    May 2014
    Beaverton, Oregon
    Hi folks,
    One additional bit of info. I replaced my fuel filter at the same time as I did the Canister-ectomy. One thing to know is that the clamp that holds the fuel filter in place does not have a captive nut on the back side.
    If you simply remove the bolt that you can see:
    the nut will fall away; quite possibly in one of those black voids, never to be seen again.
    I used a 10 mm box end wrench to hold the nut & then VERY carefully removed it.
    Jerry Baumchen
    Apr 2010
    La Plata, Maryland
    All good posts.
    I think the procedure is basically set with a variance or two. I put my fuel filter between Hose #24 and a hose that was already routed underneath the Spyder vs the fuel filter at the end of #24. its all zip tied to the frame and away from the engine. I am sure it will work just the same. So far the surging/bucking and gas smell are eliminated. Thank you to everyone, past and present, for the instructional posts.
    Aug 2018
    Thousand Islands
    Thanks for the write-up BajaRon, just had mine done.
    Aug 2018
    Thousand Islands
    Is vasectomy just as easy ? I need that done next or i risk loosing my spyder
    Quote Originally Posted by donhy View Post
    Just a heads - up ….. REMOVING the cannister Might make your Spyder Un-inspectable …… Go to my Albums , I posted pics - labeled " Gas smell Fix " there is a written explanation ( if you enlarge the pic ) of how to cure the problem and leave the cannister in …… Mike
    May 2014
    Beaverton, Oregon
    Hi donhy,
    Re: Is vasectomy just as easy ?
    Actually, much easier; I did not have to do any work.
    Jerry Baumchen
    May 2017
    Boise, Idaho
    Hey look! I can see the little triangle at the top of the fuel gage-that I never saw until I did my canisterectomy. Another added bonus! Thanks Ron and Jerry for all the help!
    2014 Can Am Spyder RT Limited with Can Am trailer
    2008 GS , Standard Seal Floorboard extension with Spyder logo cut out and teflon spacers to raise it. Yellow/Black
    Jan 2019
    Washington state
    Does anyone recall the diameter info for hose #24 and the coupler? I want to make sure I pick up the proper supplies for extending it down the frame a bit (as instructed).
    It would be nice to have the right stuff on hand before I begin.
    Thanks in advance!
    2019 RTL , Phoenix Orange Metalic
    Jan 2020
    Cluj-Napoca, Romania
    Hi,
    I want to do this procedure to my 2008 Spyder with only 350km on board, but I saw the final part on the hose above the exhaust pipe and this is NOT a good idea!
    I will go to the front of the bike, put the hose in a thermal plastic near the engine, I hope this is better.
    Sergiu.
    Quote Originally Posted by Sergiu1 View Post
    Hi,
    Sergiu.
    I recommend running the vent hose up along the right frame tube (sitting on the Spyder) to the back and terminate under the rear fender. The vent tube originates near the right front of the tank. If you have any fumes at all they will exit behind you rather than in front of you. And you avoid being anywhere near the engine, as you will if you go forward. This also keeps the entire vent tube above the fuel tank except for where you go downhill at the very end. This way there is no possibility of any fuel pooling along the way. I put a clear, lawnmower fuel filter (like the one pictured below) at the end of the vent hose so that I can check to see if any liquid fuel is going out and to keep anything from getting in. This has been done many ways. But I still think this is the better way to go.
    Dec 2019
    Western Colorado
    Thanks for the write up on this, definitely something I need to do before the riding season kicks in full time.
    2012 RS-S , Baja Ron Plug Wire Kit and NGK Iridium Plugs Grey and Black
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    I have read about this and was trying to find the hose size, which I think is 1/4. I believe the fuel filters are 5/16. While looking at the illistrated parts breakdown I noticed that there is California models and non-California. My 2012 RT was purchased in Ca and I brought it to Nevada. Is this procedure the same for both Ca and Non-Ca bikes?
    Thanks, Bob
    Dec 2019
    Western Colorado
    Doing this change this week since I have it skinned for the new air intake and filter. Get it done since its down, than I can start on the Xenon light kit, and handle bar risers..
    Quote Originally Posted by krakum1967 View Post
    I accomplished the fix a bit differently - I didn't remove the cannister, I just routed the hoses so that NO gas could ever enter the cannister …. if there is some gas in the cannister now, it will evaporate.....and as long as no more is going in any issues will cease …. I have good pics and written explanations …. in my album of the same name …. good luck …. Mike
    Quote Originally Posted by jarvis View Post
    Thanks, Bob
    All Spyders have the evap canister. It is a federal, nation wide, requirement. Sorry, I do not remember the vent hose size. But 1/4" is probably in the ball park.
    Jun 2018
    Pahrump NV
    Thanks Ron. While I am in that area with all the tupperware removed, is there anything else I can look at, remove, modify?
    Bob
    Dec 2019
    Western Colorado
    I finally did this job, kept putting it off, and that was dumb, I can run the trike in the car port now and not get gas stoned, I think part of me will miss that, but its really not good for you, and doesnt set a good example for neighborhood kids either....
    Anyway, I had a fuel filter exactly like the one pictured hanging in the shop, and I have moved it to 3 different houses and shops now, its been 8 years of "I will use it someday", piad 95 cents for that thing...I finally used just it, and the extended hose. I use the filter as the joiner tube, and I ran forward, I had enough hose to vent it through the same holes as the radiator drains, but it runs way up high on the high frame way before that, not gonna get any drips there, and its forward of the engine, and goes out the tube hole for the radiator reservoir drain.
    OMG, the SMELL IS GONE....its like a BB King song playing in the back ground, substitute thrill for smell.....
    Thanks for this guys, its works for sure, and yep, I see the top corner thingy in the gauge now, and it filled a bit more than usual I think, I will have mileage tests later to prove it. THE SMELL IS GONE!!!!!!!
    That's good news in any language (or song)!
    Aug 2012
    Central Coast, CA
    Thanks, Bob
    I did it on my old 2008 Commiefornia edition and it was the same. And, I will add that it DID make a big difference. DO IT!
    2020 RTL SE6
