Results 1 to 10 of 10
    Active Member FalconAF's Avatar
    Mar 2019
    North Las Vegas, NV, Third Rock From The Sun
    Default Help Installing New Motobatt Battery
    In my 2018 RTL
    The OEM battery has an indented lip on the top of it and the top battery holddown plate has two downward pointed lips that hang down into. The lips fit fine into the indented OEM battery. The Motobatt is level all the way across the top of the battery with no place for these "lips" to hang down into. So the holddown won't go "flush horizontal" on the top of the new motobatt.
    What to do?
    Thanks for any insight.
    Rick
    2018 Spyder RT Limited
    Mar 2019
    Hey, never mind. We just put the overhead holddown in a vise and bent the 2 "lip" tabs so they were horizontal. The holddown then went flush with the battery top and everything clamped down fine.
    Nov 2018
    Claremore, Ok.
    There are two slots in the frame above and to the rear of the battery compartment that those lips slip into. You may have had the clamp upside
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Mar 2019
    I'm not that ignorant. Neither is my niece's husband who helped me put it in. The lips you are talking about are on BACK of the clamp. The difference is in the two batteries top construction. The overhead clamp that came with the OEM battery was designed to fit the OEM battery with it's top indented geometry. The Motobatt battery sold as "for all RT models" isn't the same geometry on the top of it. If you buy the Motobatt, you're gonna HAVE to bend the 2 tabs I'm talking about. I can post pictures if you want to see them.
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by FalconAF View Post
    Ok, my bad. Some peeps here aren't always as mechanically inclined as others. I wouldn't mind seeing the battery you put in for my future reference.
    Tag-Along trailer
    Garmin 396 LM GPS
    New Banshee AGM
    It will be interesting to learn how the Motobatt performs via-a-vis a Yuasa. The battery holder is an inexpensive part, $12.50 from CCP, if one had to replace it.
    Jul 2010
    Las Vegas, NV
    Exactly how I have done it, many times. Good job, Rick! Joe
    Joe Meyer
    Active Member duke50's Avatar
    May 2014
    IL
    I would put my money on Yuasa, the best motorcycle battery on the market, IMO. Mines still running strong 6 yrs now, 2014 RT. I'm sure its getting close to its life span though.
    Active Member STELLING MAN's Avatar
    Oct 2014
    Southern Ohio
    Battery
    2013 Viper Red RT S-SE5 All 48 states on a Gold Wing now I'm working on getting all on a
    Oct 2014
    Southern Ohio
    BATTERY, I'm not putting any Chinese made battery In my RT-S as long as Yusa's are being made..
