Results 1 to 22 of 22
    May 2019
    Switzerland
    Question Ryker 900cc performance upgrade
    Hi all, recently I bought a new Ryker Rally and I'm super happy with it. It's a lot of fun and now my weekends look differently than before. Fantastic product which I think could be even better than now.
    All is well however after some time I noticed that after 40-60 mph dynamics isn't so well as I would like to have. If you had opportunity to drive F3S you'll get it immediately especially when you do downshifting. So I asked my dealer whether they have anything to improve this power lag and make it more aggressive at a speed higher than 40-60.. And surprisingly they said that they have upgrade for Ryker!!! They gave me a test vehicle with upgrade in it and I can say that you can feel noticeable difference from the very beginning. It is an upgrade which will make your ryker faster than f3s from 0-60 (my perception). I'm going to try it this summer but before I would like to ask if any of you had some info about anything like that. My key concern was possible damage of the engine because of increased HP, but dealer reminded me that this engine you can find on Maverick an SeeDoo where it has much more power (turbine plus different algorithm).
    Saying that I would like to know what do you think about this upgrade? Does anyone know if it is something from can am or it is local dealer initiative?
    I checked also CVT belt and Iit seems that we have belt from the maverick. So probably it worth to try it.
    Aug 2015
    Crosby,Texas
    What does it do to fuel mileage?
    May 2019
    Switzerland
    No idea, but I really don't care. Ryker is not about fuel economy, it is for fun and drive. So I would like to make it powerful than it is now. At the same time I don't want compromise on the reliability of it.
    May 2019
    NY
    Is it a tune that is done on the bike they had??
    Kansas
    I have only had my 900 Rally for a week but honestly I don't see it needing any more power than it has. If it's a dealer tune and they will back the warranty why not? if it's not a dealer tune and the warranty goes out the window then I would be hesitant for sure.
    Default Interesting....🤔
    Have not seen or heard of any such modifications though it is still pretty new on the market. Keep us informed as you may be the first to be here doing this upgrade on the Ryker...
    May 2019
    Switzerland
    You are right, it's an official dealer offer, so I believe that warranty is not an issue. For me, it's more interesting to understand whether this upgrade will influence on engine recourse. If it will give more torque from the beginning it could reduce rpm at 50-70 mph. I will write a report after the installation. Would be great to know your thoughts on the chip tuning.
    Personally, I have to admit that from the start I have more than enough power, but at higher speeds acceleration is not an ideal ((( I'm comparing it to Spyder F3S. With the upgrade, your acceleration will be even better than the spyder. Still, it is not confirmed by any metrics, so more subjective feeling.
    Jan 2019
    Charles Town, WV
    Since he is in Switzerland I wonder if it is tuned differently then USA models and what he is having done just brings it up to what we have here already.
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    If the tune significantly reduces RPM at 50-70 mpg I would be interested. However I believe the same RPM effect might be possible with relatively inexpensive CVT modifications; still waiting on the aftermarket for that.
    2019 Ryler Rally , Shock Yellow
    Feb 2019
    New Jersey
    Only upgrade I've read about so far is from http://fastryker.com/ According to their website for the 900/Rally:
    With this tune, you will experience the following:
    Increased acceleration
    Increased throttle response & less throttle lag
    Moderate changes to normal mode
    Drastic changes to sport mode
    ECO mode is unaffected (if applicable)
    Higher RPM limit
    increased fuel efficency in cruising RPM's
    Virtually undedectable by all scan tools and factory diagnostics.
    Sep 2012
    Stetson, Maine
    More than likely it has to do with springs. The CVT is very tunable.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    May 2009
    Connecticut
    The 900 in the jetskies makes 90 HP with only 2 Quarts of oil. There are tunes for the Jetski that increase it to 100-105 Hp ? I don't think it needs it. If you have owned another Spyder you will find the Ryker NOISY??? And without the Assisted power steering it will be twichy on back roads.
    Sea Doo GTI-SE 90 Jet Ski!!
    Dec 2018
    Czech Republic
    I think overall power is sufficient but as Neu770 I can feel a lack o power between 35-60 mph. Especially when exiting tight corners I can imagine much better acceleration.
    Oct 2015
    English Lake District
    My thoughts exactly, it lacks punch from 40-55 ish.
    Johnson, Vermont
    I think this can be adjusted to some degree with clutching changes. In contrast the 900 ACE in the snowmobiles is pretty flat from 1-30 mph, then pulls hard from about 30-65, mph. Falls off some after that and tops out around 85-90 mph
    Feb 2018
    SC
    Anybody try the flash tune stuff yet? Power vision three
    Jan 2009
    austria
    there is a different mapping for America and Europe .. in Europe the throttle is "limited" till 50 mph to only 75% .. thats why the US-version is faster than ours ..
    but its not a problem to load up different mappings, I also like more a version with a flat torque curve .. you find five diferent versions of the 900 ace on their webside
    https://www.rotax.com/en/products/ro...rtrains.html#1
    here you see my test with the European Version ..
    https://www.youtube.com/watch?v=WgRZF8wdbaE&t=7s
    Oct 2019
    Sweden
    Thanks for the information Chris56, that is very interesting.
    I have noticed that around 50mph/80kmh my Ryker Rally really takes off, now I finally know why. I will have to check with my dealer when I get the Wheel lugs replaced, if they can change the software.
    Jan 2009
    austria
    Quote Originally Posted by Greven View Post
    I heard its about the new EU "noise" regulations for Bikes .. with this CVT gearbox it was too loud for this "tests" ..
    Mar 2019
    Depoe Bay Oregon
    Glad you shared this info, I never found mine to lack power. Over 90% over my miles are at 55mph plus. A little role of the throttle and I'm doing 80 if I'm not careful. It is loud , I bought a stereo and bar mount speakers and never bothered to install it as I doubt I could hear it anyway.
    Jan 2009
    austria
    Quote Originally Posted by oregoncoast View Post
    LOL ..but if you install a windshield or a fairing ..she gets twice as loud as before, I testet it !!
    Mar 2019
    Depoe Bay Oregon
    Yeah I got one of those cam am windscreens, BUT I put on a horn that even scares me sometimes. I have a little less than 14,000 miles and it looks 10 years old. I try to take care of it but it was not made for salt air.
Tags for this Thread
