Results 1 to 16 of 16
    Dec 2009
    Canada
    Default Light Blue Tint for RT Wind Deflectors
    The clear plastic wind deflectors under your RT windshield, and beneath your mirrors, can be tinted to a light blue colour based on the following recipe:
    1. Remove wind deflectors you wish to tint;
    2. Clean the plastic with warm water and mild dish detergent;
    3. Sprinkle a healthy quantity (25 grams or so) of Black Fabric Dye (commonly used to dye fabrics in a washing machine or basin) and add a few drops of dish detergent to a pot of boiling water large enough to submerge the deflectors you wish to tint;
    4. Fully submerse the plastic in the boiling solution for approximately 30 minutes;
    5. Remove the plastic from the solution and rinse in warm water to remove any excess dye from the surface.
    That's it. Your clear deflectors will have absorbed the dye and will have taken on a blue tint. If you are looking for a lighter or darker tint just play with your process time.
    You may ask yourself why a black dye produces a blue tint during this process? The simple answer is ???? I have my theories, but without knowing the chemical elements of the dye I would merely be guessing.
    Nov 2011
    Las Vegas, NV
    Quote Originally Posted by NorthStar View Post
    I would think its because the deflectors are already blue... Just a very very light blue. you can see this by shining a white light directly into the base and looking at the edge... It's bluish... The black dye simply makes the surface layer a darker blue.. Just a guess.
    I attached an example with the white light shining in it.
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    d0 they not melt or warp in boiling water?
    Dec 2009
    Canada
    No melting or warping after 60 minutes.
    Blazing Member fastfraser's Avatar
    Feb 2009
    Orangeville, Canada
    Great mod North Star How the heck did you ever figure that out ?
    Happy Owner
    Dec 2009
    Canada
    All those years of sewing and craft classes finally paid off....
    Just happened on this recipe while surfing the web looking for ways to discolor plastic.
    Well this is a real nice piece of information! Thanks for passing it along to all of us!
    Looks very nice.
    Jun 2011
    Donaldson Arkansas
    If I had a big pot, I would try doing my whole windshield. maybe a bond fire and a no. 3 wash tub.
    I beleave I will try this tonight. not with the windshield but... looks cool.
    Invalid Emails
    May 2011
    Gulf Coast of Texas
    Thumbs up
    Quote Originally Posted by Farmboy View Post
    I was thinking the same thing, but she told me to hold that thought.. But I'm impressed the results. Great idea and awesome look..
    So...... Does Spydette have a big-enough pot in the pantry to make for an interesting weekend full of experimenting???
    Dec 2009
    Canada
    If I had an Orbital Blue RT I would be very pleased with this dye job and call it quits. However, mine is a black RT so its back to the drawing board.
    My next experiment with the wind deflector will be to coat it with black VHT tailight lens tinting spray paint to try and get the effect I am looking for. If it turns purple in the process I will finally give up.
    Active Member doncanfix2's Avatar
    Aug 2019
    MD
    Tried this today and did not get the blue tint, can barely see a difference. My receipe was a full package (31.9g) of Rit black dye and an ounce of Dawn into four gallons of water. Boiled the water and then went to a simmer at just under 200°F, submerged for a full 40 minutes, no dice. Perhaps my dye solution was too weak? Perhaps BRP has gone to a different plastic (mine is an '18). Anyone have suggestions? I have heard of a stonger Rit "Dyemore Synthetic" dye recommended for acrylic and acetate fibers.
    2018 RT Limited , OXFORD BLUE METALLIC Dark Edition
    This thread goes back to 2012.
    And...many of us have been caught with oldposts. Ask me how I know?
    about the old thread bit, but it does sound like your dye solution was pretty weak!!
    I would've thought you'd need to use that much dye (25-35 grams or so) dissolved in just ONE gallon of water to get close to the correct solution strength - and IIRC, you really only want to use just enough water to completely submerge your items, then once you bring the solution to a boil, put the items in, make sure they're fully covered, and then keep them submerged with the water/dye solution at a just rolling boil for 30 mins or so... but it has been a loooong time since I've done anything like this, so you might have more up to date info?!
    And of course, there are now all sorts & colours of tinting sprays available to colour clear & opaque plastics; there's also various films & wraps you can 'stick on'; &/or you could also try the thicker spray or brush on stuff like plasti-dip that's out there too - so you can probably find a lot of quicker & easier ways to achieve the same end...
    Aug 2019
    MD
    Thanks for the thoughts, and yes, I did see the date, but had to start somewhere! I did this in my garage in a deep fryer, and chose to vertically suspend the four pieces I wanted to do, thus requiring quite a bit more water. I did also try doubling the dye quantity (64g) and increased the dwell time, just began to see a darkening, but only very slight. My research on methods did not turn up too many specifics on the proportions, but it did lead me to the Dyemore product and inclusion of acetone (5-10%) in the mix, so I'll see how that works. The acetone concerns me because of possible crazing, but in solution at that concentration is probably okay. Certainly having a piece to experiement with would be desireable. Yes, paints, films etc. are all alternatives, but I kinda like the dye method.
    1/24/20 Update
    I have now sucessfully tinted the wind deflectors on my '18 RT, here are the details:
    Procedure:
    1. Remove the deflectors and hand wash each piece with a soft cloth in warm water and mild dish detergent. Suggestion: After washing and IF the deflectors are not brand-new, it is best to remove any surface oxidation or scratches. Any irregularities in the surface will affect how the dye deposits onto the surface; oxidation causes the dye to appear blotchy. To remove the oxidation, gently polish the surface with a clear plastic polish such as Meguiar’s PlastX™.
    2. Combine water, dye, and a small amount of dish detergent in a shallow pan, enough to fully cover the deflectors to be tinted. I used 5L of water, a full bottle of Rit DyeMore® Sapphire Blue dye (207mL), and one tablespoon of Dawn dish detergent. Bring the solution to a boil.
    3. Fully submerse one of more of the deflectors in the solution and maintain boiling for approximately 30 minutes.
    4. Remove the deflector from the solution and submerge in warm water to rinse any excess dye from the surface. Remove from rinse water and gently pat dry with a soft cloth and then hang to fully dry for several hours before touching the surface.
    Commentary and Observations:
    It became apparent that the existing condition and age of the deflectors seemed to have an effect of the final surface appearance after dying. My deflectors have been exposed to the elements for about one year or so since the unit was first uncrated. This means some minor oxidation and certainly several wash cycles have occurred during this period; this affected how the dye deposited on the surface.
    Given the above conditions, I considered my deflectors to be in near perfect condition with no scratches and a very clear, smooth surface… or so it appeared. So, all I did was hand wash them before dying; I did not initially polish the deflectors as suggested in the procedure above. After dying I noticed the bottom two deflectors had a more uniform finish compared to the upper deflectors (flanking the windshield). I reasoned this to be because the upper two are more exposed to the sun (UV degradation) and cannot be washed as thoroughly as the bottom two, which have slightly less (direct) sun exposure (due to location) with both sides exposed for easy cleaning. (As noted above and below, I did also try the black power dye method, this could have also contributed to the blotchy appearance, but only two of the four deflectors had this undesirable appearance, so I think oxidation was more likely the problem.)
    To improve the finish of the top two deflectors I then chose to polish the surface, with the initial intent of re-dying these two pieces. As polishing proceeded, I was able to remove the blotchy appearance, but I was also removing the dye and returning the plastic to a clear condition. (This certainly shows the dye is only penetrating a very thin top layer of the plastic.) As I stopped polishing to observe progress, I found I liked appearance (flat surfaces clear with perimeter edges still blue, see pictures), so I decided not to dye again.
    The final result looks pretty good I think! (Kinda hard to tell in the picture with the deflectors mounted, but the bootm ones blend in and virtually disappear, which is what I wanted! Maybe the top ones could be re-done in grey or black.)
    And one final note on the dye. I did initially try the black powder dye without much luck. I’m not saying this won’t work, I probably used too much water so the dye concentration may have been the cause. After some research into dying methods and agents I did discover this DyeMore® product from Rit (this is not an endorsement!). This dye is meant for synthetic fabric materials (the black power or liquid dye is for natural fibers), and certainly, the deflectors are not made of a natural fiber material! Those of you with different color rydes, Rit does make this dye in quite a few colors!
    Happy motoring one and all!
    Last edited by doncanfix2; 01-24-2020 at 02:36 PM. Reason: Updated Final Tinting Results
