Results 1 to 5 of 5
    Dec 2019
    San Antonio, Texas
    Default Help with a code!!
    New 2019 Spyder F3 Base Model purchased on 12/21/19 and currently 125 miles
    What does this code mean?
    Thanks Arcamguy
    2022 RT , Marsella Red
    Sep 2014
    USA
    5 ECM Lost communication with CLUSTER (lost of CAN ID’s) Missing CAN ID. Blown fuse Module internal error. Damaged circuit wires or damaged module pins. Check for cluster fault or ECM fault. With unit connected to BUDS with MPI2, Turn ignition switch OFF, wait for cluster to turn off. Disconnect MPI2 from DLC connector. Measure resistance between DLC-1 and DLC-2 (expected value = 50 to 70 ohms). Measure resistance between DLC-1 and ECMB-C1 (expected value < 2 ohms). Measure resistance between DLC-2 and ECMB-C2 (expected value < 2 ohms). Measure resistance between DLC-1 and CL-24 (expected value < 2 ohms). Measure resistance between DLC-2 and CL-23 (expected value < 2 ohms). Turn ignition switch ON Measure voltage between harness connector CL-8 and ground (expected value = 11 to 13 volts). tmr2013-077 3
    Take it back to the dealer for warranty
    Dec 2019
    San Antonio, Texas
    Everything seems to work fine, can I still drive it safely till I can get it to my dealer? They are closed for inventory till 1/7/2020 and I cant take it in till 1/11/2020
    Sep 2014
    USA
    Do you still have the code after you shut it off and try to restart it?
    I would call the dealer and ask them if you can drive it or if they will tow it back for you since its under warranty.
    Dec 2009
    West Oz
    Welcome to SpyderWorld & SpyderLovers.
    Do what Triker says.
