Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 117
  1. #51
    Jul 2016
    Murfreesboro, tn
    Question
    I'm planning on making a 9,000 mile trip this summer and just discovered the new Mobile 1 Annual Protection.
    Would this oil work correctly in my 2008 GS and help me to avoid an oil change on the road? I'm just now looking
    at its codes and ratings, but figured some of you that travel more than me could provide some insight or ideas.
    We could either continue using this thread or use pms to keep out of the technical and arguing discussions that usually
    ensue.
    thanks,
    tntherapy (Dick Beistel)
    Last edited by Peter Aawen; 05-21-2024 at 05:33 PM. Reason: Removed Post title after merge - they mess with Searching! ;-)
  2. #52
    This Mobil 1 - There are sooooooooooooo many types of oil that come under the Mobil 1 name it's almost impossible to tell what its specific properties are ........ so can you look the label for what the grading classifications cover and post it here...... then we can tell you if it's OK ........... I will say that the longest mileage oil is going to be a Full Synthetic, they won't break down as quickly as Dino or Blended Dino oils do ............... Mike
  3. #53
    Northern Kalifornia
    Running 9k on an oil change is ok. However, you will likely need to add oil before you make the 9k miles. Keep that in mind and take extra oil with you. Also, make sure you are using Mobil motorcycle oil. Do not run regular automobile oil in your spyder. Regular vehicle oil contains friction modifiers that will interfere with your clutch pack. If you get somewhere and need oil and can't find motorcycle oil, any diesel motor oil will work in a pinch and will not harm your clutch pack. Delo 400 15w40 will work great. Good luck and have a great trip.
  4. #54
    Nov 2012
    North Las Vegas, NV
    Use the Mobil 10w40 motorcycle oil not the annual protection stuff, that’s for cars. I’m running the Mobil Racing 4T 10W40 full synthetic motorcycle oil now and will be changing it soon. I’m running it for over 8,000 miles now and will send it in for analysis. Report to come.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
  5. #55
    Apr 2011
    GREENVILLE, SC
    it ABSOLUTELY requires oil that is specifically made for motorcycles...
    WET CLUTCH
    oil is the ONLY oil to use... you will ruin your SPYD3R if you use oil that is specific to automobiles....
    Dan P
    SPYD3R
  6. #56
    with Dan... It's the wet clutch that should be your biggest concern.
  7. #57
    Active Member Spyderglide's Avatar
    May 2017
    Wildwood, Florida
    2016 Spyder RT-S Special Series (black)
    Garmin Zumo 590 GPS with Mounting Kit & Locking Plate
    Battery Tender Jr
    Full & Half Covers
    Foam Grip Covers
    NBV Highway Brackets with Black Dually Trident ISO Pegs
    3- Piece Lid Net Set
    Baja Ron Sway Bar with Aluminum End Links
    Magic Mirror’s
    Doc’s Vibration Damper
    Air Ryde Rock Armour Cup
    Missing Belt Guard
    Dual USB Charger with Digital Voltmeter Rocker Switch
    IPS Axel Caps Front (inner) & Rear
    GoldPlugs MP-01 & MP-18
    Yuasa YTX24HL-BS Battery
    Battery Post Risers
    Tie Down Rings
    Show Chrome Rear Trunk Shock
    2- Beaded Seat Cushions
    Tinted Sport Windshield & Side Cargo Bag Set (stored in a box)
  8. #58
    Which Mobil One oil is used in our 1330 Spyders. I have been looking at the backside labels and can't find any with a JASO rating - Please state the exact product and weight of the oil.
    Also, Rotella has a great rebate until end of Dec. If anyone has been able to PRINT the rebate form, please share how you accomplished this. Much Thanks. Mike
  9. #59
    Mar 2013
    Mike,
    I have used Mobil 4T it is Jaso and Jaso 2 rated - per their website. It is 10w-40w oil. I have since changed to Rotella T6 as it is as good and cost less (even without the rebate).
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
  10. #60
    SoFlo
    Mike
    The Mobil 1 oil you are asking about is Mobil 1 Racing 4T. 10W40.
    One of the bottles I had on the shelf is labeled JASO MA, another is labeled JASO MA2. Not sure why this is? However, I did check the Mobil website and it is stating the oil is JASO MA2 rated.
    Our 14 RTS has had Mobil 1 Racing 4T 10W40 as the only oil used except during engine break in which used the BRP oil.
    No complaints against the Mobil 1. Seems those owners that have had oil analysis done for this oil get very good reports.
    I decided on the Mobil 1 and have stuck with it based on 540rats independent testing of hundreds of oils. The last time I checked the 540rat blog page, the Mobil 1 was still rated considerably higher in the rankings than the Rotella T6 and other oils that are wet clutch approved. I believe there is one Motul oil that is acceptable for Spyders, but it remains very expensive. Want to add, when I last checked the blog, no Amsoil motorcycle products had been tested at that time.
    https://mobiloil.com/en/motor-oils/m...motorcycle-oil
  11. #61
    Aug 2019
    Stoughton, WI
    2022 RT Sea To Sky
  12. #62
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
  13. #63
    Nov 2012
    North Las Vegas, NV
    I have tested Mobil1 4T 10w40 and Amsoil 10W40 and the Amsoil held up better.
    Amsoil on the left, Mobil 1 on the right. Note the mileage.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
  14. #64
    Nov 2018
    Waynesboro, PA
    look the same to me? Correction My bad I see what your saying you ran Mobil 1 (in the right column) for 8,654 miles First then tested, then you changed to Ams Oil and run that for 9,666 miles shows (in Left column ) both test show on the same sheet, same sheet is shown twice. Good info Thank You!
    My Spyder
    2012 RTL , Brown
  15. #65
    THANKS to all that have responded ......I still would like to know if someone has successfully PRINTED the Rebate form ……. I want to but it at Walmart, and the On-line form won't let me because it isn't on the list they have...… but others have bought it at Walmart and got the Re-bate …….Thanks, ..Mike
  16. #66
    Mar 2013
    Mike,
    Earlier this year I was able to get the rebate after purchasing the oil from Walmart. On the form was listed other for where you purchased it from so I chose that and put in Walmart. Looking at the form now I see that that option has been removed.
  17. #67
    Feb 2012
    Spring City,Utah
    Mike what is the web address for that rebate coupon?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  18. #68
    SoFlo
    Yes, I recall that you did switch. I have not switched basically for two reasons, actually three. I change the oil at 5000 miles. Not saying Mobil 1 can not go further, simply, it aligns with a good calendar time frame change interval also for the amount of use our Spyder gets. The other two reasons, essentially, and not discounting oil analysis, but honestly it is not the same as actual testing the oil as 540rat does in his blog. He truly tests oil and has proven method and ranking system, not influenced by any sponsorship or industry input. Add to this, Mobil 1 Racing 10W40 motorcycle oil is the second highest rated motorcycle oil designed for wet clutch use by 540rat, only the Motul oil ranked higher and was almost three times more expensive. Mobil 1 was considerably higher rated in his wear tests when compared to other oils, not Amsoil, that are commonly recommended here.
    As many people know and understand, the actual engine is fairly easy on the oil, the gearbox and clutch will tear the molecules apart. Which indicates all the more reason to ensure a high psi rated oil, not actual oil pressure, but rather film strength becomes important, so it shears less over time as the gearbox grinds it up.
    At this time, and I checked earlier today, the Amsoil products designated as moto oils have not been tested by him. Possibly when tested I may switch.
  19. #69
    Oct 2014
    Loudon, TN
    I just received my rebate check, $7 per gallon. My rebate was from O’Reillys and the forms were in the store. As I recall the T6 was about $21/gallon less $7 rebate.
    2014 RTS SM6 , Cognac
  20. #70
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    I did the rebate online. https://rotella.shell.com/en_us/coup...L0RJWS90NXQ2Lw
    Just got my check.
    2020 RT Limited , Petrol Blue
  21. #71
    Aug 2019
    Stoughton, WI
    Geeez ... I knew this would come to an oil thread. Good luck with the rebate form
    2022 RT Sea To Sky
  22. #72
    Clinton, MS
    Quote Originally Posted by Michaelscs View Post
    Just got my check.
    Bet there are several web addresses for different versions of this form. The one in your link states, "Valid at participating farm retailers only."
  23. #73
    Nov 2018
    Waynesboro, PA
    Yes just what the OP was all about two oils and a rebate form. I think the OP got the info he was looking for with a link to the rebate and more.
    My Spyder
    2012 RTL , Brown
  24. #74
    Just got my check.
    Great …. who did you buy the oil from ????? ……………...Thanks, Mike
  25. #75
    Quote Originally Posted by CopperSpyder View Post
    I have had that LINK for awhile ….. But I can't find a way to Print it !!! ...…that's my issue ……….Thanks ….Mike
