Results 1 to 14 of 14
    Aug 2019
    San Antonio, Texas
    Default F3s mirror shake
    So I've read about the fixes for the f3t, but since the f3s has different style mirrors, is there a fix for them rattling around so much? One car looks like two cars in the mirror.
    2019 F3s , Titanium
    NorCal - Northbay
    Hmmm, that's quite odd. Mine are rock solid and always have been... I can't even recall anyone with an S complaining about them being loose. Have you checked the mounting bolts? Is it the actual mirror portion that is loose in the housing or the entire unit?
    Chuck
    Houston
    Lamonster Garage has a great kit to move your mirrors up to the handlebars where you can actually see with them.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Apr 2016
    Bloomington, Minnesota
    Joe Meyer from squared away has a Wedgie mirror fix. It tightens up the whole mirror housing.
    Harrington, Australia
    Quote Originally Posted by PapaHotel View Post
    Yeah, but they are only for the F3-T or F3-L, Papa. The OP is asking about the F3s which has different mirrors
    HeliBars Handlebars
    Kenda Kanine rear.
    Dec 2012
    Murphy, NC
    I have an F3-S and have no mirror shake. I would check the bolts in the mirror arms to be sure they are tight against the body. Also check any screws in the mirrors themselves to be sure they are tight.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Aug 2019
    San Antonio, Texas
    How do I check the screws in the mirror itself? The bolts against the body are all tight, good there. I took one screw off behind the mirror, but I can't figure out how to get that part off. The end piece is a little loose. That may be what's causing it but it looks like I can't get to it without taking that one piece off.
    I'm at work so I don't have the manual with me. Should've brought it, there's nothing to do at the moment.
    2019 F3s , Titanium
    May 2013
    Apex, N.C.
    Not sure about how to help, but I did notice from the picture that you have a 2019 (no turn signal on the mirror). That might give others a heads up as to what needs to be done to tighten the mirror. Good luck.
    Mar 2013
    Try this -
    Down where the two screws that attach the mirror to the body there is an 8mm bolt above them. Try tightening them. They control the swing in of the mirrors.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Aug 2019
    San Antonio, Texas
    Swing arm of the mirror is fine. Nice and tight. It's the mirror housing itself that's a little loose. The part that's in the picture I posted, that's what's a little wacky. The piece that holds the mirror in place. If I could open that up, I think that will give me what I seek.
    If nothing else, I'm taking it in for its first service soon so I'll have the dealership look at it.
    2019 F3s , Titanium
    NorCal - Northbay
    Quote Originally Posted by Millermatic252 View Post
    Once the screw is out, you will need to "help" it let go of its seal against the mirror housing by prying it a bit AND DO IT FROM THE END THAT THE SCREW IS AT.... The other end "hooks in" for lack of a better term. It can be in there really tight so you may have to get a bit physical with it. I've had the best luck with going at it from the bottom edge right across from the screw hole...
    Chuck
    Dec 2012
    Murphy, NC
    I think your owners manual shows you how to get the turn signal lens off. Once off, check for anything loose in there.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Mar 2013
    Like you I also have mirror vibration. Seeing your thread I went out to my hibernating for the winter F3s and removed the screw to the lens cover, and attempted to remove it. As you found out it don't want to come off. I did tap the back of the lens and noticed that the whole mirror vibrated. I than tightened the 8mm nut a little more (it was tight) and tapped the lens again. This time the mirror assembly did not vibrate. I do not know if this fixes the issue since I am unable to ride to verify, but looks promising.
    This is why I suggested trying it on yours to see if it helps.
    Aug 2019
    San Antonio, Texas
    So I think I've fixed it. I got the back plate off, and then there were three bolts to tighten. Tightened them because they were a little loose. Now the mirror is solid. It doesn't do anything to the mirror itself, but the housing part was loose. Now it's not.
    2019 F3s , Titanium
