Results 1 to 13 of 13
    Jul 2013
    Brights Grove, Ontario, Canada
    Default Any better alternatives to BRP Signature Light?
    I'm interested in purchasing this particular product,(sku 219400599 cost $209.99 CAD) but before this happens does anyone know of another alternative that is equal or better and possibly less expensive.
    2017 F3-S , circuit yellow
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    2020 RT Limited , Petrol Blue
    Cambridge, Ontaio
    Tricled also sells some great products. https://www.tricledusa.com/spyder-f3
    Aug 2017
    Brooksville FL
    I also have the Lamonster Bright Ryder and love it for visibility and at night. Also a lot cheaper and super easy to install.
    2016 F3-T , Lamonster break pedal extender White
    Aug 2019
    Stoughton, WI
    Gonna get me a Bright Ryder
    2022 RT Sea To Sky
    Jun 2018
    Pa.
    Quote Originally Posted by Bubalub View Post
    Does the Lamonster Bright Ryder include the light under the frunk and across the bottom?
    Thanks in advance,
    Jim
    Aug 2019
    Stoughton, WI
    Think it's just the frunk light..
    2022 RT Sea To Sky
    Mar 2013
    Quote Originally Posted by JimH View Post
    Thanks in advance,
    Jim
    No - as that is on the lighted bump skid.
    http://www.lamonstergarage.com/can-a...ster-approved/
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Mar 2017
    I got a "Signature" light before I took delivery of my 2016. Within the 90 day warranty period half of it went dark. I reported it to Johnny K in Niles OH
    and asked for a replacement and they told me that it was a light and BuRP won't warranty lights. I mentioned it on here and got several responses that it was NOT a light but an LED so try again. I did. This time they took pictures and said they would try to get it done. I called back in about a month and they said BuRP denied to fix it. I mentioned that here again and it was recommended to me to contact BuRP directly in email. I did and they told me to take it to the nearest dealer which was down here in Greenville SC so they could check the "history" on it. I did and there was NO history because Johnny K in Niles OH did NOT report it.
    I will NEVER buy anything from JK Niles again. I actually fashioned my own solution to the problem of the empty space under the frunk lid. It cost roughly $20 and plugs into the OEM signature light harness.
    Full details ON MY PAGE >click here< This shows the white/amber switchback light I made. I have on order Blue/Amber to match my fog lights.
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Default Lamonster’s Bright Light
    I purchased Lamonster’s F3 Bright Ryder signature light for my 2018:F3T
    He has an excellent video to show the installation see:-
    https://youtu.be/1spTbzK85_M
    I’ve completed the install I made a change because the Bright Light lead runs under the Front trunk and very near one of the Cooling hoses which will give off heat
    I added Flexible Corrugated Conduit to give extra protection
    The tubing is clipped to ensure it does not catch the Trunk hinge as it open & closes
    I’m very impressed with the light output and should aid my visibility to other road users
    See photos :-
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Jun 2018
    Pa.
    Quote Originally Posted by Rattlebars View Post
    That is really slick - I really like it!
    Aug 2019
    Stoughton, WI
    Before I spend $60+, I think I'll try some ebay/Chinese cheapo's for a $1.75 WTH ...
    https://www.ebay.com/itm/2Pcs-Car-12...y/254428493889
    2022 RT Sea To Sky
    Mar 2015
    Indianapolis, IN
    I went with this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    EDIT: Interesting - the seller changed the link or something on Amazon - that link is cut right out of my order - but now doesn't show the Red/White light I bought - it only shows a white only version. This is close to what I bought - but this is blue instead of red - https://www.amazon.com/SZMAITOU-Head...omotive&sr=1-2
    My Wiring is a bit complicated but I can explain:
    I use the AUX line in the Frunk to power the White side - so when the Spyder is running the white light is on.
    I used my other LED light set-up to wire the Red side - so when my other LED lights are on - the Red is on.
    HOWEVER - I also used the AUX Line mentioned above and a Relay - to cut power to the Red lights when the Spyder is running. So the end result is:
    1) Turn on the Color Changing LED - the Red lighting on the front lights up.
    2) Turn on the Spyder and the Red lights go out - the white light lights up - but the rest of my ground affect light is unaffected.
    I love this set-up - and it was very cheap.
    Last edited by Jdr00ejr; 11-22-2019 at 02:08 PM. Reason: Added additional information.
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    2019 Spyder RT Limited
    2016 F3S , Triple Black
