Results 1 to 18 of 18
    Dec 2016
    Iowa
    Default Battery access????
    2016 RT Limited, battery is dead, bought a charger and gosh, what a headache can's really get a very good bite to attach charger to terminal. Is there any aftermarket fixes that can install to improve access to allow jumping? I saw a few things for an F3 but haven't come across anything yet for RT. Any help would be greatly appreciated. Thanks,
    2016 RT Limited , Black
    Faribault, MN
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Dec 2016
    Iowa
    Thanks, saw the video on the F3 on You Tube but didn't see anything on the RT, will contact them.
    Bossier LoUiSiAna
    Quote Originally Posted by Tyris View Post
    If you can’t get the clamps to bite, might wanna go ahead & install a charging pigtail
    image.jpeg some chargers come with one & a set of regular clamps.
    & I thought after 2013 all had the charge/ jump post on upper side of frunk?70AC0AC0-FEF5-4C29-A3DF-8F810E5F6917.jpg
    Mar 2013
    Not from BRP, but a lot of dealers put them on.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    This is what I installed on my 16 RT. Easy install .!
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    Faribault, MN
    The Tric LED option is for jump starting ANY Spyder's with front batteries, the battery tender pigtail is for slow charging, having both doesn't hurt.
    Safe Rides,
    IBA 70020
    I'm leaning out of my foxhole a bit on this but I'm pretty sure the pigtail is for battery tenders only; the wire gauge and probably the fuse is not big enough for jumping a Spyder. Mine came with a pigtail and Battery Tender Jr. and I have a Rugged Geek from Lamonster for jumping that I've not used -- yet.
    Dec 2016
    Iowa
    I have the battery tender already installed, left it on all might but didn't budge it, still completely dead. I bought a charger at Thiessen's and have it precariously attached, and although it's showing green saying that it is "Charging" when I turn the key there is no bootup screen. It's only a 6A charger so either have to wait longer. To jump it with cables maybe could hold the clamps against the terminals but would need another body and extra pair of hands. Not thrilled with the idea of holding them on there.
    This is another case of BRP shortcomings that just frustrates the hell out of me. My guess is their engineers do not "actually" ride the product they design.
    Feb 2012
    Spring City,Utah
    Remember a battery tender does not put out enough to charge a dead battery. You will need something stronger. And a dead battery takes awhile to come back so be patient and give it some time.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Bossier LoUiSiAna
    yes the pigtail is for charging/ maintaining only, but the other post on top of frunk are for easier access to jumpstart & can attach the pig tail there as well, you just clamp directly to the post for jumping not the pigtail. Sorry if was phrased poorly.
    No apology necessary. Your post sent me to the Tricled web site looking at their positive post jump cable and it definitely has merit, particularly if I had to use my Rugged Geek; no muss, no fuss, just pull it out and pop it on.
    Nov 2012
    North Las Vegas, NV
    If where the battery is on your RT bugs you, take a look at the battery location on a 2012 or older RT.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Dec 2016
    Iowa
    Yep, saw that on a Finless Bob video, you are in far worse shape, still would think that since the goal was to improve it on later models, this was their solution? Should be shot or forced to jump start RT's for eternity.
    Mar 2017
    Myrtle Beach, South Carolina
    Use a meter and check the amount of volts it has, it might not have enough amperage, you might have a bad battery also.
    Nope. Only the 2013s had them, at least as the RTs are concerned. I guess somebody at BRP decided they weren't useful enough to keep them after 2013.
    INDIANA, USA
    Default Battery
    Well, I'm still waiting to hear about your Fix on the Spyder.
    Battery, loose wire, or something else?
    Check Battery Tips here on the Spyder Forum.......
    ENJOY YOUR LIFE WITH A SPYDER
    Nov 2018
    Claremore, Ok.
    Those pig tails have a fuse in-line, if it's not passing current check the fuse. Also, you might want to check fuses/relays if it won't start. I installed a Hella Type plug receptacle to the right side under the handlebars with 10ga wire with a 30 amp inline fuse connected to the battery junction bolt behind the right side fuse block. That's where I plug in the battery charger or to give or receive a jump start. I also have a USB port that can plug in there to power heated vest.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
