Results 1 to 11 of 11
    Aug 2013
    SF Bay Area
    Default Saddlebag interior straps??
    Has anyone tried installing interior straps for the saddlebags? Just in case the lid pops open it would be a good idea to have the gear strapped in. I know there are bags but then you have to get the bag out to find what you're looking for and the straps will hold stuff in place but allow you to see where it all is.
    Kinda like this.
    2021 F3 Ltd , Magna Red
    Apr 2014
    Beloit Kansas
    sounds like a good project for you...emphasis on YOU. Design something repeatable
    and maybe you can sell or manufacture.
    Nov 2018
    Des Moines IA
    Kinda like this.
    I have spent a lot of my free time trying to find something that is available. So far no luck. Maybe a do it yourself winter project at home for me. Such a simple safe guard for a saddlebag popping open.
    2018 Spyder ST Limited , Asphalt Gray
    Jun 2010
    Las Vegas
    There are mesh nets available for the outer lids but on the inside you don’t have screw points to work with. I had a test bije in 14 and the side cases came open frequently but on my personal Spyders I have never had one open while riding.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    My soft sided Hopnel bags carry the saddlebag stuff; does the trick for me.
    Nov 2018
    Des Moines IA
    My soft sided Hopnel bags carry the saddlebag stuff.; does the trick for me.
    We had a bag pop open and the bag fell out at 70 MPH. Not cool at all.
    Apr 2015
    Tucson, AZ USA
    Here's what I did using shock cord, original mounts, and a few homemade pieces. Cost was very little and it's worked very well for me.
    Rob
    PA
    Not sure if it would work or not but how about this. Goto Harbor freight and buy the larger motocycle helmet net. The s hooks snap off. Then goto the auto store and buy plastic eyelid cable anchor or here is an example of ones from a hardware but are probably to stiff. Same idea. Remove the screws I have depicted, screw them back in over the eyelids that are wrapped around the ends of the motorcycle helmet net. Might work. I never had one pop open but I can see if my BRP saddle bag insert did come open it would suck to have it fly out at 70. Just a thought
    PA
    As a side note. I was thinking about this. I’d rather it fly out than have some type of tether that the bag could be pulled into the rear wheel. All hell would break loose then. I’d rather it fly out. I don’t think the door would rip off just lose everything.
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    My '99 BMW RT had elastic retaining straps inside the saddlebags, just as you are describing. You might see if you can order those parts from them. Might have to drill some small holes to install them. FWIW, I've also had my saddlebags pop open, and I think something like this would be a great idea.
    Aug 2013
    SF Bay Area
    Lots of ideas to work on for the cooler months. I did a 507 mile ride this last weekend and stuffed the bags with rain gear, cold gear and whatever and they were really stuffed! Was a bit concerned that if a bag lid popped open all would be lost. Will post a solution if I figure it out.
    Thanks!
