Results 1 to 18 of 18
    Member glorybiz's Avatar
    May 2018
    Ellicott City, Maryland
    Default Do you actually USE your Heated seats? What do you think of them?
    Just wanted to get an idea on how many of you with heated seats actually use them and do you think it was worth it?
    I only ask as I am at that tipping point were I plan to upgrade my seat this year and I have never had a heated seat before
    thanks for your input
    Ron
    2016 RT Limited , stock yes red
    Mar 2013
    Hi Ron,
    The first time I had a heated seat was on a BMW 1200. Since then all my RDL seats are ordered with the heat option. We use them often on cold rides as it helps take the edge off. Why not be more comfortable!
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Jan 2019
    NW GA
    I've never used a heated seat before, but the Spyder I am picking up Saturday has one. Not sure if it will get used or not, it's going to be 70 there and 40's when I get home. Maybe towards the end i'll kick on on LOL. I know I love the heated grips that I put on my Honda ST1300.
    Nov 2013
    Oro Valley Arizona
    Confucious say, he who ride without heated seat get cold butt along with cold feet.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    May 2018
    The russell day long is what I have been looking at for my replacement seat. How do you like it?
    Ron
    May 2018
    Funny, I thought confucius said that "profanity is a sign of a weak mind trying to express its strength"
    Ron
    Default Don't know...
    I may be alone on this or my anatomy is different but my butt nor my palms get cold when ryding. I do have heated gloves and heated jacket liner. I do ryde an RS and my hands are exposed getting full on wind so the gloves are on a seperate temp control. Some heat in under the Jeans and good to go. But then there are a mess of folks out there that swear by the seat and grips being heated....
    Mar 2013
    Quote Originally Posted by glorybiz View Post
    Ron
    I found it to be the best seat out there. When we first got our 2014 RT I tried the BRP comfort seat, then a Ultimate seat than finally went with Daylong. Should have just started with Daylong as I have had them on my Harley's.
    Now we have two F3's and just got Daylong's for both!
    The nice part is RDL gives you 8 months to make sure it's right for you, and after two tries in that time frame if they can not they will refund your money. In the last 3 seats I have only had to have them correct it once (on the first seat).
    Feb 2016
    I had the heated comfort seat on my 15 RTL until buying a heated Ultimate seat last Oct. I use the heat a lot, since I ride year round unless there's ice in the forecast. It's very comfortable. If you're interested in the Can Am heated comfort seat, I have mine for sale.
    2020 RT Limited , Marsala Red
    Sep 2018
    greensburg,pa
    I have the Can am comfort heated seat-a little more room for me and the heat is good. (Wife says hers(passenger) gets to hot on Hi). Had it on my 2006 Goldwing and was surprised a RT-L didn't come with it.
    Yes it's worth it!
    2018 RT-L , Blue
    Jul 2010
    Las Vegas, NV
    Heated seats are great. RDL makes a great seat. Laamseats are fantastic and about half as much as a RDL. We have both, in fact, we have 2 Daylong’s and a Laam. Being comfortable is priceless!
    Joe Meyer
    Linden, CA
    conformax.jpgSeat :Gel .jpg
    Here are the (2) best things that can be done to a motorcycle seat in terms of
    making it an all day comfortable seat.
    There is NO NEED to spends several hundred dollars on an after market seat
    just to get comfort, this is a job you can do yourself using hand tools you
    have or can get at Harbor Freight.
    The seat heater is $89.95 and the ConfortMax Gel Kit also $79.95.
    Any of your local automotive upholstery shops can also install this for you for
    about 1 hours labor at their labor rate most charge $85 to $100
    ask anyone here on the forum who has don this to their seat and they will tell you
    it made the stock seat super cumphy for an all day ride...
    Call me today and get yours
    Ride Safe and warm
    SF Bay Area
    Replying to old post but still.......
    I just got the Russell Day Long and am installing today. It is heated. Any advice you care to share on how to hook up the heater? How to run the wires etc.? Thanks.
    Sep 2019
    Prague, Oklahoma
    Jetfixer, I realize that this is an old post but do you still have the comfort seat for sale, if so how much?
    2019 RT Limited , Pearl White
    Mar 2013
    Quote Originally Posted by martiniman View Post
    I ran wires directly from the battery with one being fused connected to a 30amp relay that is powered from a keyed on wire. Since that keyed power wires job is to only activate the relay it doesn't draw much power. This is then connected to the seat. I did not like trying to draw the power needed for the seat from existing wiring, and that is why I did the direct to battery.
    Linden, CA
    HI Dave here
    I have in stock the OEM type seat heater units and the
    wiring harness with the control switch. ONLY $89.95 ea.
    this is an easy do it yourself install, and while your there
    you may want install my Custom made medical grade
    seat Gel with memory foam to make your seat better than all those
    super high price after market one size fits all seats.
    you can put Gel and heater in your stock seat for $168.00
    DO IT YOUR $ELF AND $AVE
    CALL ME TODAY or email me at motorcycledave@mac.com
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    Glorybiz:
    From one Legion Rider to another go for the heat. I have it on my 2015 RTL and I have a new 2020 F3 Limited on it way but it doesn't have the heated seat but it will once I get it.
    We'll have to hook up for a ride sometime. I am with ALR Post 143 in New Cumberland PA.
    2022 RT Limited , Silver w/ Black and Purple accents
    Active Member wd8ajj's Avatar
    Las Cruces NM
    I found an aftermarket from china that lies on the seat and works nice. 9.95 free shipping, Found it on the "WISH'" App.
