2020 rt
They shrunk it. Saddle looks more sculpted. Nice evolution in the marque.
Earlier model years should get a boost in resale value from this development I think.
2014 RTL Platinum
![](signaturepics/sigpic20671_7.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by UtahPete
They shrunk it. Earlier model years should get a boost in value from this development I think.
They said they lowered the seat but the driver has 2" more leg room and Passenger has 1" more leg room.
It sounds like accessory add-ons will be more modular and similar to how you accessories are added to the Ryker. More DIY for those non-mechanics like me! I'd buy one!
One question, does the wheel base look wider than the previous RTs?
![](signaturepics/sigpic30747_2.gif) ![](https://www.spyderlovers.com/forums/maps/map.png?states=SD.WY.NE.IA.MN.KS.MO)
2017 Spyder RT Limited - Champagne Metallic Chrome
- Wolo Bad Boy Horn, SPYDERPOPS Next Gen LED Bumpskid, SPYDERPOPS Double Vision Daytime Running Lights
2021 Spyder RT Limited - Deep Marsala Metallic Dark
- Replaced 2021 Stock Handlebars with F3 Stock Handlebars, BRP Adjustable Driver Backrest, Wolo Bad Boy Horn, SPYDERPOPS Double Vision Daytime Running Lights, SPYDERPOPS ""BRAKER BARS" Brake/Run Lights
Looks kinda F3-ish. Makes me wonder if they're discontinuing it. Finally, after all these years, all LED lights up front.
I like how that top case is removable. I'm kind of digging the redesign... It needed to be freshened up.
Happy Former-Spyder owner! ![thumbup](images/smilies/thumbup.gif)
2008 SM5 PE# 3518 / Intense Blue Pearl (sold 2014)
![](signaturepics/sigpic1204_3.gif)
The top box is better than the F3 even though it looks the same.
2017 F3 Limited
In the trash can, it was. They spent about 5 mins on the Spyders and only 2 at that. No mention of any engine changes. Very short and simple. Was very upset with the outcome.
Intriguing.......might be saying bye-bye to my ‘14 RT
2020 RTL SE6 Asphalt Grey
2014 RT SE6, Pearl White 57k (2014-2020)
2008 GS Premier 17k (2012-2014)
The top box is better than the F3 even though it looks the same. LED headlights.
2017 F3 Limited
Not too crazy about all the straight lines and the front end.
2017 F3 Limited
2017 F3 Limited
Larger trunk capable of holding 2 helmets. Adjustable floorboards. No mention of the dash.
Looks like an FT and F3 limited only on the next level of luxury.
2017 F3 Limited
![Quote](images/misc/quote_icon.png) Originally Posted by Flamewinger
The top box is got gas shocks and a stronger lid with metal hinges. No more flimsy lid.
2017 F3 Limited
Can't get a look at the dash and they offer a Garmin GPS. No radio, no anything about music or entertainment.
Whew...... I thought they might have come out with a higher performance shaft drive that would make my bike obsolete. Looks like same-ol-same-ol cosmetic upgrades. No reason to jump to the "new" stuff...... Jim
Semper Fi
![](https://www.spyderlovers.com/forums/maps/map.png?states=WA.ID.MT.WY.CO.UT.TX.NM.AZ.NV.CA.OR.OK)
Shrunk ??? ….. specs say 4.5 +/- longer ……. Mike
They will have the new Tech dash but more storage. The rider part of the seat flips up for gas letting the passenger stay put. Adjustable floorboards. Removable trunk.
I find it interesting. I sure hope they did a better job with the top case, frunk and side cases over what they did with the F3.
2020 RTL SE6
![](signaturepics/sigpic10748_5.gif)
I like the looks of this when the trunk is off. Nothing that I would switch up for, but the larger saddle bags (larger than my F3T) are nice. I also like the larger frunk.
So they now put the RT on the F3T/L chassis with a different set of body work. The old RT chassis was introduced in 2013 and was the same as the RS and ST. So I guess time to go.
![](signaturepics/sigpic7798_4.gif)
