Thanks for the link! Code that came up was P0000. Is this "limp mode"?
Try to pull the codes after its shutdown on it own and not turn off the key switch until you can pull the codes again. Dont think that's a valid code.
And try disconnecting the battery for 5 minutes then hook back up to see if it will start?
Just throwning out some thoughts for now..
what octane gas have you put in it lately ? ( as in possible water in the gas ? ) when trying to restart the cycle " in gear " I think you really have to push down on the brake to get the sensor activate the starter ....
I recently filled with non ethanol fuel. Last Spring, I added stabilizer to the fuel just in case I had some water in the fuel. I'll "stand" on the brake and see if that works!
Tried the brake again, nothing. I did check the codes again and it showed a E3EOC. Any ideal what this is?
It will not shift out of gear with the engine stopped. Step on the brake pedal while trying to start. Also check the Stop/run rocker on the right hand grip and see if that is pushed to stop. If those aren't the problem then take off the left side panels and you can see the shift lever and shift shaft. You can manually move it into neutral and then load it on a trailer to take to dealer.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
