Do the 19 f3t and the 19 f3 limited have the same exact rear sprocket.
Does anyone really know for sure, just looking for the truth. Might make the difference between buying the t or the limited. Road a f3- t a few weeks ago and this thing had told of balls , very snappy. Just ordered up a limited today , just wondering if I made the wrong decision.
Reason: Incomplete spelling
Same size sprocket on the T and L
2021 Sea To Sky, 2020 RTL
but our benefits don't?
Good choice. Lots of other good things come with the limited . . floor boards, heated grips, auto leveling suspension, rear trunk . . . . really happy with mine
Are you able to manually put air in on the limited like you can on the t rear suspension.
![Quote](images/misc/quote_icon.png) Originally Posted by snowdevil
Nope . . . all automatic
formerly pman2011
![Quote](images/misc/quote_icon.png) Originally Posted by PW2013STL
This is why I brought an 2018 T, Brp stopped putting the larger 89T sprocket on for the 2019 F3T's. I drove an 2018T and liked it so much I decided to trade my RT for one.
[B]
2018 Intense Red F3T (See About Me under My Profile for mods)
2010 Timeless Black RT-622 Trailer
2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
All 2019 F3's have a 79 tooth sprocket on the rear excpt the "S". {corrected}
https://www.partshark.com/oemparts/a...ve-system-rear
![Quote](images/misc/quote_icon.png) Originally Posted by Rattlebars
So can u change out the 79 tooth for the 89 tooth, or everything will be off on u , speedo, speed sensors . Theoretically should be no problems except ecm programming
Ozzie Ozzie Ozzie
Not true. The F3S still comes with the larger 89 tooth sprocket. Base, T and ltd come with the small sprocket.
![Quote](images/misc/quote_icon.png) Originally Posted by jcthorne
True...but if you were to UPGRADE to the 89 tooth sprocket and belt on the 2019 F-3 base, touring and limited..and Upgrade the BUDS software..to reflect the change it should work...it won't work on the RT...people have tried...but it should work on the F-3 series...has anybody tried to do the upgrade on an F-3 series bike?...that's the question.
