Results 1 to 15 of 15
    NOVA
    Default Belt Replacement Help
    I just took off the rear wheel and can't figure out how to get the belt off and around the frame. Does any one have a video on how replace the belt?
    2015 F3 , Gray/Black/Orange
    LA
    I would think you need to take the belt off the front pulley to give you slack.
    NOVA
    Tried that. The frame won't allow it to fully come off. Has to be some type of trick.
    Durham,Maine
    If you took the fender or swing arm off so you had the belt on the out side of that frame rail would that help?
    2012 RTL , Pearl
    Durham,Maine
    I have the rt, so I watch a you tube on a tire change, couldn't get a good view of the ass end but that was what I was thinking!! Good Luck!!
    2012 RTL , Pearl
    Active Member bcraig's Avatar
    Grove City, OH USA
    Can you post a photo of what you are dealing with and circle the area that is giving you a problem?
    Nov 2012
    North Las Vegas, NV
    According to the Service Manual: Take off the left side body panels and there is a lateral support you unbolt below the fuel tank, then you can get the belt out that way.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    NOVA
    Is that in the manual?
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by aracrash View Post
    When asking a question please tell us what model and year of the Spyder you are asking a question about. For the specific question you are asking it makes a difference. F3 forum, so I guess a F3, but there are many types of F3s. May I suggest putting the spec of your ride in your signature. That way you do not have remember to do it everytime you ask a question.
    For stuff like this it is helpful to have a service manual. A digital copy is cheap and you just download it and usable in an hour depending on your internet speed.
    Florida Swamp
    Later models F3-S
    Removing the Drive Belt
    NOTE: Mark the direction of rotation. Drive belt
    must be reinstalled in the same direction to obtain
    the maximum drive belt life span.
    1. Lift rear of vehicle by the frame until rear wheel
    is off the ground.
    For SM6 transmission, refer to GEARBOX subsec-
    tion and remove the shift shaft lever link rod.
    2. Remove engine cover.
    3. Remove dark body panels. Refer to BODY sub-
    section.
    4. Remove rear left passenger footrest.
    5. Remove rear fender assembly. Refer to BODY
    subsection.
    6. Remove rear belt guard.
    7. Loosen the tension on the drive belt.
    8. Remove drive belt.
    Page 508 F3-S Shop Manual
    https://brpmanuals.com/canam-spyder-manual.htm
    2019 F3-S , Black & Silver
    NOVA
    Thank you. Was able to get the belt off easily with your instructions. I am now waiting on the new belt to arrive and about to purchase the shop manual.
    Appreciate the help.
    Mar 2015
    Tacoma WA.
    Remove the big side panel, the seats and the smaller panel near the footpeg.There is the foot peg bracket and guard near the front sprocket. Those need to come off, easy peasy!
    2017 F3-S Daytona , Yellow and black
    NOVA
    Everything finished up nicely!!!
    Mar 2019
    Fla/NJ
    what is the recommended time or miles for when to change drive belt?
