Results 1 to 9 of 9
    Active Member mehcoib's Avatar
    Montreal, QC
    Default What is this SAE connector for?
    Hello!
    I found this SAE connector, does anyone know what it is for?
    Accessories plug (I hope so!) or battery charging?
    2015 ST-S SE5 , Blue & orange
    Aug 2018
    north wis
    Likely battery tender plug. Also useful for heated gear if you get adapter.
    Sep 2014
    USA
    for a battery tender
    Montreal, QC
    Oh... So, can I plug my USB adapter for my cell?
    Faribault, MN
    You might check it with a multi-meter, but it's likely, as woods and trikermuthr said, a direct connection to your battery. So it's both yes to your original question.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Default Well....
    not looking like any heated gear plugs I have been around but could be. I would think it is more likely a battery connection. If you can get to your battery you will see the connection there...
    Sep 2014
    USA
    Quote Originally Posted by mehcoib View Post
    Does your USB adapter have the same type of plug? As the picture indicates it maybe a 12 VDC source direct from the battery.
    As DGoebel stated a volt meter would help to see if that plug still has power to it.
    But most just use it for a battery tender hookup point.
    Very Active Member SpyderConvert's Avatar
    Catonsville, MD
    Deltran (Battery Tender) makes an adapter that has a USB port and connects directly to the SAE plug.
    2015 RTL, BajaRon Swaybar, LaMonster LED Headlights and Foglights, LaMonster Spydercuff, LaMonster LED mirror wrap, Magic Mirrors, HMT Brake Light
    2015 RT Ltd. , $" extension Black
    Montreal, QC
    I tested with a multi-meter, it's a direct connection to the battery. I guess I can use it for my USB connector (it has a SAE connector on the other side) but it looks like the polarity is reversed!? I don't want to damage my cell... I should probably follow the wires to the battery and see how they are connected.
    It looks like an addon to my Spyder but I'm surprised since previous owner did not make any modification...!
