Results 1 to 17 of 17
Thread: Rear brakes
    Sep 2016
    LI NY
    Default Rear brakes
    2010 RSS
    I have Ron's pads, no matter what I do I cannot get the
    Piston to retract enough to fit them on. I spoke to Ron and he said I am doing everything correct. They are not screw in. I bent a C clamp trying to move them. I tried WD40, I tried tapping with a mallet but it only goes so far. I am missing by like a 1/16 inch.
    Any ideas from the collective minds of SL?
    Thank you in advance.
    2010 RTSM5 , stock Stock Silver
    Nov 2015
    Chardon, OH
    If the piston still has room to retract and it's not flush with the caliper yet, the parking brake mechanism is the first thing that comes to mind. You're working on an RS? Pull off the lever and rotate the shaft a bit further in the disengage direction.
    Doug
    ”Freedom is not a loophole”
    I am sorry that you're having so much trouble with your rear caliper. Did you turn the parking brake shaft where the arm attaches to the caliper, counter-clock wise?
    Here is a video that shows this.
    https://www.youtube.com/watch?v=qnIgEZ1pgRw
    Jan 2019
    Hunter Valley NSW Australia
    You may also have no alternative but to disassemble the caliper to check there is no debris behind the piston preventing it from getting "home". The down side of this is that you'll then need a overhaul kit.
    2017 RTL , White
    Sep 2016
    LI NY
    It's done, thank you Snowbelt and BajaRon. It was the parking brake. Spent 2 hours fighting with it, once I knew what to do 15 minutes and done.
    Thank you to all for your comments
    Quote Originally Posted by Zip View Post
    I am sorry. I know we discussed the parking brake over the phone. I thought you said you already did this. I should have been more detail oriented. I apologize for the added grief!
    Sep 2016
    LI NY
    No worries Ron, it all worked out in the end.
    Thank you again
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Quote Originally Posted by askitee View Post
    Is there an overhaul kit for these?
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Jul 2018
    Lake Stevens, WA
    any full videos out there I have yet to locate? struggling hard here to get the hex/allen head bolts even loose
    2009 GS , MSD wires Red/Black
    Feb 2012
    Spring City,Utah
    what year and model are working with CANUSASwede
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jul 2018
    Lake Stevens, WA
    @Pegasus = 09 GS. ***UPDATE*** have the hex/allen bolts out. YEAH! New/current issue:: cylinder (?) PISTON is all the way "OUT" and not going "IN". do I just empty brake fluid altogether to resolve?
    Nov 2015
    Chardon, OH
    09 GS. Try this video.
    https://youtu.be/NnKVCGc4cLw
    Doug
    Jul 2018
    Lake Stevens, WA
    @Snowbelt... Chris Farley in his coke prime
    Nov 2015
    Chardon, OH
    Quote Originally Posted by CANUSASwede View Post
    Sorry. I don’t get it. But....the way he installed the C clamp. Is that not working for you? As you push the piston back into the caliper, the fluid will be displaced back up into the reservoir. There's no need to empty it out of the caliper - it doesn't cause a hydraulic lock. But, if your reservoir is already very full, you'll want to suck out some fluid in order to make room for what comes back. And as above, you may need to back off the parking brake shaft in order to allow the piston to fully retract into the caliper. Turn it CCW.
    Doug
    Jul 2018
    Lake Stevens, WA
    the presenter of the video reminds me of Chris Farley in his heyday of snorting coke while on SNL was all.
    not working for me, at the moment, unfortunately. reservoir is full, caps are off. parking brake shaft is also all the way out, CCW.
    Nov 2015
    Chardon, OH
    I don't think you're doing anything wrong then, and I think I recall a couple of folks experiencing your issue, too. It's a matter of a slight misalignment of the piston because it's so far out. Keep at it and you'll get it.
    Doug
    Jul 2018
    Lake Stevens, WA
    didn't realize this post hadn't yet actually made it... this has been resolved, THANK YOU! now onto the fronts
