Results 1 to 18 of 18
    Sep 2014
    USA
    Default Anti Freeze Alternative?
    Anyone know of an alternate Anti Freeze Versus the BRP brand to use?
    This would be for a 2014 Spyder RT.
    Mar 2015
    forrest above Reno, Nv
    I'd like to know also. I'm sure BRP doesn't make antifreeze and just has it put into a BRP container. I would think any antifreeze rated for a modern motor will work.
    Lew L
    2014 RTS , Circuit Yellow
    Sep 2014
    USA
    I did find something from Amsoil. But I had to go to the 2018 Models. The Amsoil is one of those that an be compatible all types of Anti freeze.
    There is a Antifreeze alternative out there that is compatible with all types of Anti freeze.
    I know I used a Prestone on my car that was compatible with all types of anti freeze.
    Have to do more research.
    May 2017
    Perry Hall, Md
    Have you tried a search of "coolants" as that the most common term. Many, many threads on requirements and ones to use
    2011 RT , Yes Blue
    Default Little checking.....
    There are a lot of coolant for motorcycles out there. I know BRP changed to a pink version but don't know why. You basically need the lubricant and glycol with water and be aluminum safe. Water is still the best and due to our weather and ryding here I run a 75% water 25% antifreeze mix. You could get the specs on the new stuff and see if the other coolant meet them...
    Oct 2014
    Fort Mill, SC
    I use good old Prestone in everything. It is non-silicate so it will not harm aluminium.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Sep 2014
    USA
    ethylene glycol antifreeze for Aluminum engines can be used.
    Amsoil looks like a good alternate
    https://www.amsoil.com/shop/by-produ...ode=ANTPC1G-EA
    The Spyder takes around 1 gallon
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    The color of coolant means nothing any more. There was a time when that was a good indicator of the type of coolant you had but that is no longer true.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Jul 2010
    Las Vegas, NV
    Peak 50/50 in the blue jug. 12 bucks at NAPA. MSDS IS EXACTLY THE SAME AS BRP’S coolant. Same stuff, 1/2 the price.
    Joe Meyer
    Sep 2014
    USA
    Prestone in a Blue Jug? Peak maybe?
    never seen Prestone in Blue only Yellow.
    Jun 2019
    New Jersey
    Chupaca a 50/50 mix is what you should be using. Anti freeze does more than prevent freeze up. It lubricates and prevents corrosion and a 50/50 mix with distilled water is the minimum mix and best.
    For me since I don't find the need to change anti freeze every year I stick with what the manufacturer recommends. It doesn't pay to mess with cheaper stuff for a few dollars saved. I would rather have the piece of mind knowing I used the right stuff. Yes I know BRP doesn't make anti freeze but they probably have theirs made to their own specs by an outside manufacturer.
    Sep 2014
    USA
    ethylene glycol antifreeze for Aluminum engines can be used. Does not have to be BRP as most likely it was source from another vendor and then slapped a BRP label on it and ask for double the price.
    Active Member Tatonka's Avatar
    Jan 2018
    North Carolina
    you can get brp pre-mixed bottle at amazon for a reasonable price ...2 day free shipping with amazon prime.
    mine is a 2013 rt s and who ever engineered the placement of the coolant reservoir should be brought up on charges!
    Mar 2016
    Highriver,ab.canada
    I just picked up 1 litre of pink anti freeze for my 2016. Parts guy told me green in 2013 twins is a 5 year change out. Pink in 2014 and newer has a 10 year change out.
    Only needed a cup full to top it up but was scared to add wrong stuff.
    Sep 2014
    USA
    Think it 5 years or 150K for the pink, Green is 2 years..
    Jan 2018
    mondovi wi
    Make sure your antifreeze says LONG LIFE - it is compatible with all other antifreeze.
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    If it meets other requirements I'd suggest looking for PROPYLENE GLYCOL coolant. It is non-toxic, whereas ethylene glycol is poisonous and tends to kill things.
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by Tatonka View Post
    If you take off the Tupperware below the headlights the Radiator cap is easily accessed. But I agree about that engineering.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
