Results 1 to 7 of 7
    Apr 2013
    Vancouver Is. BC /Arizona
    Default lid locks and mirrors
    Can you use lid locks with the bar end mirrors? Thanks Bob
    Northern Kalifornia
    Best to ask lidlox about that.
    Apr 2013
    Their website says yes but real life experience doesn't hurt.
    Mar 2016
    Indiana
    I think Lamonster was working on a mirror that would work with the Lid Lox.
    Dec 2018
    NY
    I have the lid lox installed on my RALLY with the bar end mirrors. They were purchased from Lamonster. No problem with the install, I used the longer bolt that was supplied with the kit.
    Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
    Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
    2022 F3S, special series , Manta Green
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    I am also using Lidlox with the factory mirrors. No issues....they installed in a few minutes.
    Jan 2015
    southern WI
    Yes you can. The stock mirrors have an insert into the bar ends that has a nut inside of it. You can use the same stock bolt for the LidLox kit. Just pull the bolt out and use the lidlox assembly as you normally would. Very easy
    2016 RTS , Pearl White
