No rydin with boys today!
I drive a 2018 F3 base with 4500 miles, started just fine got about 5 miles from home engine light came on the frunk wasn't shut
completely so I closed it up but the light will not go away. checked battery connections and fuses everything is good even disconnected
the battery for a bit but as soon as you start the light comes back on WTH.
She is making me look bad in front of all my friends.
2018 F3 , Full size brake pedal Black
How about fault code P0172? and how do I clear faults?
Ozzie Ozzie Ozzie
Well Peter it was all my fault, imagine that, I topped off the fuel tank for a long ride with the boys and fuel got into the evap canister. My local
Can Am fellas hooked her up to the heart monitor reset the code and all is well. Do not overfill your tank.
The F3 is a very fun machine to ride and I will keep it for a long time.
Faith is only faith when that is all you have left.
Topping off tanks is Not worth the possible problems of overfilling!
2015 F3 SM6, Custom Dynamics fender lights.
Sea Doo GTI-SE 90 Jet Ski!!
From what I know of the 1330 engine and related systems….. I don't think it's possible to flood the EVAP canister …. BRP routed the tubes so it couldn't happen - UN-like on the V-twin engine …… Mike
You may not be able to flood it per se but after a "spillover" event into it, there will be too much residual fuel in it still when the engine starts. It will get "purged" into the engine and trigger a "rich" condition.... Even if it is only a "temporary" condition, it just has to last long enough to trigger the event.
Chuck
