Results 1 to 15 of 15
Thread: Belt Tensioner
    Jul 2019
    Virginia
    Default Belt Tensioner
    Didn't want to hijack the recent belt vibration thread. So one of the first mechanical add ons I have planned is a tensioner. Which one BRP with Lamonster roller or the aftermarket one or any other options? Thank you. 2017 RT-S. Thanks in advance.
    Sep 2016
    Chillicothe, Oh.
    Roadster Renovations
    2015 RT , Black
    Jul 2019
    Virginia
    I'm guessing the $180.00 one?
    Active Member nslowmotion's Avatar
    May 2015
    https://t.me/pump_upp
    Roadster renovations is the way to go. You will not be disappointed.
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by BigSmokeDan View Post
    Yes, that's the one.
    2015 RT , Black
    USA
    I'm running the Roaster Renovations and it seems like a very well built piece of equipment. I consider it one of my (I did say my, YMMV) best bang for the buck investments so far, it's right up there with the car tires I installed.
    But in every silver cloud, there must be some darkness. a very respected young lady that has about a gazillion miles on various Spyders had one of the rollers fail on this kit. failed at 50,000 miles I believe, think it may have messed up the belt, but not sure. So on this one, or any other brand of them, realize the roller is comparatively small, turns a whole lot of rotations on small sealed bearings, and needs inspecting at least once a year or when ever you have the plastic off whichever is sooner. I'm going to replace the roller at 25,000 miles whether it needs it or not. Rollers are cheap, belts aren't.
    h0gr1der
    Jan 2015
    southern WI
    Another vote for R/R tensioner. ALways thought I'd just get the vibes out with belt tension adjustments and alignment, but the tensioner does help. I caved in and bought one this spring. So far so good
    2016 RTS , Pearl White
    Jun 2010
    Las Vegas
    Here is my Roadster Renovations tensioner.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jul 2018
    New Jersey
    SpyderAnn01, so many miles on that roller???
    Joe
    2018 F3L , Blue
    Thinks out loud
    Apr 2012
    Add me to the list of satisfied Smooth Spyder users. That said, over the years there have been a few roller failures reported.
    https://www.smoothspyder.com/
    Jul 2015
    Kamloops B C
    I bought the BRP one for my 2017 F3T. 33,000 Kms on it without Any issues. Just be sure that it is centered on the belt properly.
    2016 RTE6 , Black
    Aug 2017
    Greensboro Pa
    Is r/r still in business?
    Aug 2017
    Greensboro Pa
    I have the smooth spyder on my 17 rt 11,000 miles no problem
    USA
    Ms SpyderAnn01,
    Just so I don't spread hearsay and gossip, what was the actual factual on the roller failure? Did it wipe out the belt? I believe I heard 50,000 miles when it failed, is that correct? I'm trying to get a handle on my replacement frequency, and your help is appreciated. I'm thinking 25,000 miles may be about right, replace it before it fails, kinda like the rear wheel bearings.
    h0gr1der
    Maine
    Make sure you get a extra spring! Mine is collecting dust in the garage. A new spring is thirty $.
