Results 1 to 10 of 10
    Thinks out loud
    Apr 2012
    Default Tips & Tricks for the first timer - perhaps beyond
    So, you're going to remove some panels and wonder how you're going to keep track of all the hardware(screws and pushpins) and where each goes on reassembly.
    Some say bag'm. Well, that works if you know what size(length) goes where. If you don't, heres an easy way to do it until you do know where they go.
    Take a pizza box and cut yourself two full size squares from the top and bottom of the box. Label one left, and one right. As you remove each screw, starting at the top left of the square push your first screw through the box(or make a a pilot hole with a small philips driver first). As each screw comes out, orient it to the box like it came from the panel. First panel off, drop down on the box and start on the next panel.
    Now, when you're ready to go back together. You know where things go. As far as where the push pins go, they're self explanatory.
    Hope this helps someone a little.
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    I've been working on our Spyder for the last three years and have tried various says to keep track of what goes where. I think this is one of the best ideas I've heard of so far! Thanks!!
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Jun 2010
    Las Vegas
    Screws that go into a painted surface have washers. We use a plastic bin on each side of the bike and it works great for us.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Good Idea...
    I have always found that placing the screws and push pins with each panel as removed helps though you still have the issue of length. Knowing the plastic washers go on painted exterior is important to remember.... will help the new adventeruing into DIY'ing
    Dec 2012
    Murphy, NC
    When I remove a panel I put the screw back into the panel and then put a small strip of masking tape over the screw. Then I don’t have to worry about which screw goes into each hole even if they are different lengths.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Dec 2008
    Syracuse, NY
    Don't kick the box. It might screw things up.
    Thinks out loud
    Apr 2012
    Quote Originally Posted by wyliec View Post
    Now that's funny
    Active Member TRBorslien's Avatar
    Mar 2018
    West Fargo, ND
    Quote Originally Posted by Jerbear View Post
    Excellent tip! Had to do this with a water pump one time. It had something like 14 bolts of three different lengths. Don't remember what it was on, but it was probably one of Ford's better ideas!
    Tony
    2012 RT-S SE5 - Viper Red
    Castle Atom SV Tarmac Modular Helmets
    Sena SMH5 Headsets
    Ultraguard Half Cover
    Hopnel Luggage: Frunk, Top Case, and Saddlebags
    Big Bike Parts Short Spiral Antenna
    Kumho Ecsta AST 225/50R15 Rear Tire - Got almost 18,000 miles before replacement with Riken Raptor
    Vredestein Quatrac 5 165/65R-14 Front Tires
    BajaRon Spark Plugs and Wires
    EBC Rear Pads and Rotor from BajaRon
    Riken Raptor HR 215/60-15 Rear Tire
    Future Plans:
    2013 Cooling Kit
    BajaRon Sway Bar
    High-Mount Brake Light
    2012 RT-S , Viper Red
    I did that with everything on my recent 56K service.
    Sep 2012
    Stetson, Maine
    Great idea.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
