Results 1 to 15 of 15
Thread: Sissy bar bag
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    Default Sissy bar bag
    I bought this from Cycle Gear. It has two Velcro straps so I could fasten it tightly to the backrest. It's a Sedici T2 Veneto Tail bag. Capacity 22 liters.
    2019 Rally , Black
    Mar 2019
    GTA, Canada
    That's actually a pretty neat idea .
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Quote Originally Posted by Rogue Hawk View Post
    I was thinking of getting that same bag. Let us know how it is working out. Do you feel it swaying from side to side any through turns?
    Kansas
    What supports the bottom of the bag? Because that flimsy plastic tail piece certainly won't support any weight without damage.
    Mar 2019
    GTA, Canada
    If the back of the bag where it straps from is solid, and the straps are strong, you most probably do not need bottom support.
    Friction should keep it in place without any issues.
    Apr 2015
    Chicago
    I rode with it on last night. It did start to sag. There is a grip on the top of the bag, so I can get a Velcro Cinch to tie from the grip to the top strap vertically. I can also invert it and let the bottom be supported by the passenger seat. Its easy to get on and off, so it's no issue. Even with the sagging, it does not reach the back fender, so there is no risk of it getting damaged or gum up the back wheel. It just looks a little odd.
    Sort of like this.
    2019 Rally , Black
    Jan 2018
    NH
    I was worried that it might sag some. There are some bags that have a pocket that goes over the top of the seat and hangs. I'm still trying to find one of those that I like the look of.
    Active Member bscofield84's Avatar
    Aitkin Minnesota
    I rigged out a back pack 4 extra storage. I added extra straps so most of the bag hand on the backrest vs just strapping onto it.
    2014 ST SE5 LT , Black Current
    Kansas
    Keep in mind the back rest is just that, a backrest. It fits into a slot at the front of the seat and is only attached at the back by 2 small screws into plastic. If your strapping a lot of weight that is pulling down on the back rest then eventually those 2 screws will strip out of the plastic. Now a bag strapped to the back rest resting the bottom on something won't do that. Folks that didn't install their own back rest may not know this.
    Default Nice...
    Could make a "L" brace for the support. Kuryakyn has some soft formed bags I use on the RS but the passenger back support is massive and I made the "L" brace to mount it on.
    Apr 2015
    Chicago
    I tested with a new strap from the bag handle fastened to the bottom strap. Works well. I put some soda and a cable lock in it, no issues. If I have to ever carry something heavy I will just turn it around so the passenger seat will support it. It is a semi rigid bag, so it won’t lose its shape.
    2019 Rally , Black
    Jun 2015
    Lagos, southwest Portugal
    Here's an idea. I reckon the OE back rest which clicks on to the F3 will take a Ventura bag slotted over it. I have an old Bathurst Pack; 63 litres, it would sit on the back seat. www.ventura-bike.com
    No need to buy the frame. They won't have one for a Can-Am, anyway. I've had my bag since 1996. I had it over one of their frames on an R1100GS, then over the Triple Tail on my Buell Ulysses and when I get my F3-S I'll measure up a back rest and see if it will fit. It should.
    Tennessee
    I added the trunk behind the seat. Saved me $300 on a backrest and have both the passenger seat and a trunk.
    Mar 2015
    Indianapolis, IN
    Quote Originally Posted by TNRyker View Post
    Do you have any details on how you mounted the trunk? Thanks!
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    2019 Spyder RT Limited
    2016 F3S , Triple Black
    Mar 2019
    GTA, Canada
    Sorry for derailing this thread a little bit... but do you have a more detailed picture on how you managed to attached that L bracket?
    Thinking on doing something similar and looking for ideas .
    Thanks!
