Which fuse on 2012 Spyder Rt Limited for rear 12v outlet?
Hello,
I have a 2012 Spyder RT Limited and the 12v outlet in the rear trunk does not work. I want to check the fuse to see if its blown, but I cannot find anywhere in the manual which fuse goes to this 12v outlet. Can someone tell me which fuse and what else used this same fuse so I can see if anything else on that fuse works. It seems as if everything else works. Thanks,
Tags for this Thread
