Results 1 to 4 of 4
Thread: Laser alignment
    Jun 2017
    Hanover Ont Canada
    Default Laser alignment
    When you install 2 new front tire do you have to get a laser alignment. I have ordered 2 bred stein quadtrax 5 tires. 175/55/R15
    SoFlo
    Has the machine been aligned before?, if so then no, you should be fine.
    Spyders are beyond basic in suspension and steering design, AND are truly only adjustable for toe setting. There is no camber or castor adjustments, so not much to get out of wack.
    Dec 2015
    Oakley Utah
    if it didn't need it before it doesn't need it after replacing tires.
    2014 RTL Platinum
    Jun 2017
    Hanover Ont Canada
    When I bought it 2 years ago from the dealer they did it then. So I should be good then. Thanks
