Rear Trunk
Hi....need some help on removing the rear trunk so I can get at the back of the USB connector and empty hole to add a female 12v plug and tie it into the power for the USB...nothing in the manual and nothing on youtube...any help would be appreciated...a lot of screws/bolts back there and I don't want something to fall off.... :0)
https://youtu.be/69GyJuJhMQk
Hershey check this video out it might help. I was impressed.
![Quote](images/misc/quote_icon.png) Originally Posted by BLUEKNIGHT911
Nope no going to happen.... I've taken my entire 2014 RT apart ( several times ![Roflblack](images/smilies/roflblack.gif) ) without benefit of a manual or diagram ….. You might want to label any ODD size bolts …. there are a couple of short ones , and I think two long ones ….. You could use the parts Fiche's from cheapcycleparts.com as a guide … they show where and what all the parts are ……. Mike ![Ohyea](images/smilies/ohyea.gif)
Hey, thanks a lot for the link....I'll check it out tomorrow...
Bill, you da Man!!!!! Exactly what I was wanting to see...never would have looked under that name though....kept looking for Rear Cargo, Rear Trunk etc etc.....
Well, finally got up nerve to attack the rear end of my Spyder to install a 12v plug....panels came off easy enough after watching videos a couple time...planned on mounting the plug in the unused spot on the right side of the trunk...wouldn't ya know, of course it was oblong and not round so I dug out my little 'nipper' tool and of course, it didn't have a wide enough bite for the thickness of the plastic...so I searched my tool box for a reamer to clean it out...so solly, no reamer...off to the hardware store...they had a really nice reamer for a drill, but they wanted $50.00 for it.(and no manual one available)..so being frugal, I bought a mandrel with a stone on it for $5.98 and took it home..got the hole enlarged and mounted the new socket...couldn't get a good crimp on the wire ends, so I looked for my crimping tool...of course, couldn't find it.. , so back to the hardware store...$9.98....got one end of the pos/neg wires attached to the socket and went to put the speaker housing back on, and of course, it wouldn't fit...have to cut some of it away....tomorrow tomorrow tomorrow....why didn't BRP put one in when they built the dang bike????
Yep...moving the fuse was the first thing I did....some days nothing seems to work right... :0( ...
I got lucky, the PO put one of those in that same location. Now all I need is an actual battery tender to connect to it.
2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
Yea, my salesman said they would put one in, but it didn't happen and I didn't ask or check when I picked up the bike....my bad....
