Results 1 to 25 of 27
    Ft Pierce/Lk Placid
    Default Does Ryker Fit w/o Major Difficulties Onto A 5 Foot Wide Utility Trailer???
    I mean, it is 59.4" wide, so there is only 0.3" to spare on each side whilst loading onto trailer.
    Kansas
    Not gonna work, you will booger something up. Heard of it happening already. Get a 6x10 or 6x12 if you can
    Nov 2018
    N.E. Ohio
    My Aluminum Triton is an 84” x 120”. This gives me room to walk around and strap it down. Plus, for me, it helps to get on and off more safely. The ramp is the full width and 4’ long. cueman
    Jun 2015
    Ritzville, Wa
    Quote Originally Posted by cueman View Post
    Is that the bed or overall dimensions?
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Ft Pierce/Lk Placid
    I'll probably get a 5.5 X 9 one.
    Probably prudent would be to BACK it onto the trailer.
    Nov 2018
    N.E. Ohio
    Quote Originally Posted by gkamer View Post
    That is the bed dimensions and it weighs 650lbs. and has the 14” wheels. cueman
    Kansas
    Quote Originally Posted by Aufgeblassen47 View Post
    Be easier to line it up if you pull onto the trailer instead of backing.
    Oct 2015
    miNNESota
    I have a 6' x 12' Triton trailer and plan on putting 2 Rykers back to back on it by offsetting the rear wheels.mkapH4oPQ%mgWa5Kvxn4+Q.jpg
    2019 900 Rally , Black
    Nov 2018
    N.E. Ohio
    And don’t forget that the front of the Ryker is heavier than the rear. Just make sure the trailer is long enough so you can get the proper hitch weight. IMO cueman
    Nov 2018
    N.E. Ohio
    Quote Originally Posted by vstrommer View Post
    How big is your shoe horn? cueman
    Chattanooga TN
    Yes, doing it backwards is always easier... lol
    Dec 2018
    NY
    Manuel states the RYKER should be transported with the front facing forward.
    Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
    Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
    2022 F3S, special series , Manta Green
    Ft Pierce/Lk Placid
    Quote Originally Posted by Jsmith8695 View Post
    Speaking of that, instead of towing on a trailer, I've just sent a message to Can-Am asking if the Ryker be towed safely (i.e. w/o transmission damage) on a dolly with the rear wheel on the ground. Will be interesting what they say.
    Will be a helluva lot less weight towing & much better resulting MPG.
    Kansas
    When the Rep at CanAm stops laughing about using a Dolly I'm relatively sure the answer will be a firm NO
    Jun 2011
    Alamogordo, NM
    Would not be a good idea AT ALL because the input pulley from the motor would be spinning a extremely hi RPM's as the CVT tranny would think it is in the lowest effective gear. The engine RPM governs the engagement of the centrifugal clutch on the motor. It would be like putting a manual shift vehicle in low gear and holding the clutch in while pulling the venicle, at the speed increases the transmission input would try to run an extremely hi RPM with the resulting serious damage to the tranny and possibly the motor should the centrifugal clutch accidently engaged. Try pushing your Ryker in either forward or reverse gear with the motor off.
    Do not try it.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Ft Pierce/Lk Placid
    Quote Originally Posted by old Timer View Post
    Do not try it.
    Okie dokie! It could be towed BACKWARDS though.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Most likely but you'll have to lock the steering.
    Oct 2015
    miNNESota
    Why would it matter?
    Active Member NewYorkSpyder's Avatar
    Feb 2016
    Schenectady NY
    Transport facing forward mainly because the windshield is designed to cut thru the wind not catch it.
    2019 Rally , GMUltra Violet
    Active Member Dragracer's Avatar
    Oct 2009
    Lecanto, FL.
    I have an 80" wide by 12' long trailer. it will fit both my Ryker, and the wife's Spyder. It's a tight fit with the Spyder being backed onto the trailer.
    Calling an illegal immigrant an undocumented worker, is like calling the corner drug dealer an unlicensed Pharmacist.
    2019 900 ACE , Stock Black
    Ft Pierce/Lk Placid
    Quote Originally Posted by NewYorkSpyder View Post
    I would slide it all the way down if towing backwards.
    Jun 2011
    Alamogordo, NM
    NO.........100% same issues period.
    You could tow only if the speed never exceeded a very low speed, something well under 10 MPH.
    Dean O
    Gran Pa Hoon
    Alamogordo, NM
    '20 Spyder F3 L
    Ft Pierce/Lk Placid
    It is so small, it would hardly matter. Plus, you can lower it all the way down.
    Ft Pierce/Lk Placid
    LOL.
    Jun 2011
    Alamogordo, NM
    LOL.
    Clearly you understand that I am not talking about towing on a trailer, only talking about towing with the rear wheel on the ground spinning the transmission.
    Dean O
    Gran Pa Hoon
    Alamogordo, NM
    '20 Spyder F3 L
