Results 1 to 9 of 9
Thread: Bar End options
    Jan 2015
    southern WI
    Default Bar End options
    My wife hates the stock mirrors, so we bought a set of after markets that she really likes. The issue is when ya take the stock ones off, it leaves an ugly unfinished end on the bars, and it leaves it useless to try to mount Lidlox because of the mirror mount setup. Does anyone have any other options for bar end caps yet? She does want a set of Lidlox as well, so I'm kind of at a loss for mounting them if I totally remove the stock mirrors.
    2016 RTS , Pearl White
    Active Member bcraig's Avatar
    Grove City, OH USA
    Lots of options. Bicycle bar end plugs to weighted motorcycle bar ends.
    https://www.amazon.com/Domain-Cyclin...ateway&sr=8-10
    https://www.amazon.com/ATOM-Weights-...gateway&sr=8-6
    Jan 2015
    southern WI
    After scouting on Lamonster's site, I see his Ryker has Lidlox and the aftermarket mirrors.....Lamont, how did you mount the Lidlox? That little wedge nut deep in the bar held the mirrors on, right?
    Jan 2015
    southern WI
    Quote Originally Posted by bcraig View Post
    Thanks....that's a great option!
    Dec 2018
    NY
    There are installation videos on you tube and the Lamonster web site
    Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
    Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
    2022 F3S, special series , Manta Green
    Jan 2015
    southern WI
    Quote Originally Posted by Jsmith8695 View Post
    Hmm, didn't check YouTube, but didn't see one on his site either...
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    S****m*ds has them in three colors for the Ryker
    Feb 2019
    Clearwater, FL
    I got these for $10 from amazon. I like 'em.
    https://www.amazon.com/gp/product/B076HHFQ4G/
    Jan 2019
    Indiana
    My GFs 900 was vibrating badly, she had trouble seeing in the mirrors and her hands going numb.
    I ordered a 12" X 13/16" piece of brass from McMaster Carr, cut it in half, drilled and tapped a threaded 1/4 - 20 hole in one end (to aid in placement and removal) milled a 1/4 inch groove halfway down the side to clear the pins for the grips and inserted it with some silicone adhesive to hold it in place.
    Each side has 6" of brass inside.
    It fixed the vibration problems and she can see clearly out of the mirrors.
