I bought the Accu-Gage in the picture when I bought my Spyder. The right angle chuck makes it very easy to check the rear tire. I have compared it to a digital gage with a chuck that won't allow me to check the rear tire but pressure-wise they agree within a quarter pound of each other.
****************************** Cognac 2014 RT-S
I have a digital tire gauge that lives in the garage. (Nothing like the one you posted. Good Gawd - I couldn't even start to consider $96.99 for a tire gauge!) Other than that, I just go down to the big box store and get a handful of 97¢ stick gauges. I air up a tire and then read the PSI with the cheapo sticks. Most of the time they will agree with each other, if one or two don't by more that a psi they get trashed. Then I read the pressure with the digital gauge. I note the difference in psi if there is any and use a sharpie to write the + or - pressure on the stick gauge.
The ones in the RTL (I carry 2 in case I give one away or lend one that doesn't come back) come from a group of gauges that consistently read 3 lbs low. Knowing that when filling the tires I know the correct air pressure for the fronts (20 psi) is reached when those particular gauges read 23 psi.
BTW, I have been told that the most accurate measurement on a tire gauge is in the middle of the range. I was cautioned to not use my 150 psi truck tire gauge to check the 20 & 23 psi tires on the Spyder.
2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
Why would anyone pay more than $10 for a tire pressure gage? Just go to Menards or Farm and Fleet..etc, and buy a $8.00 digital gage and leave it in your glove box.
I thought tire pressure was important on spyders and needed to be accurate that's why I was looking at the more expensive ones..... .... but guess any old gauge will do the trick.
I have a Motion Pro in the garage that I won in raffle. Very good quality gauge and I do use it a lot. One thing I can't use it on is the rear suspension air bag on my standard Spyder RT. The gauge won't read that high. I also have a cheap digital gauge that I bought when I was on the road and in a pinch. I have done a few comparisons and the cheapo gives me the same reading as the Motion Pro gauge. It wouldn't take much abuse to trash the cheapo gauge, but the Motion Pro is pretty much indestructible as it should be for a high dollar gauge.
Don't be mistaken, the pressure IS important, but more important is that the fronts are the same pressure. A decent digital gage helps ya get closer readings than the old slide stick style. The gage I use gets within .10 lb and it was under $10. Got it at Menards.
Got it! Thanks for clarifying that for me.....new to the Spyder.
That's what mine looks like too. Nice and accurate.
JT Machine Shop... Has a dual line single feed balance guage that is the way to go. Inflate both front tires o desiresd pressure and release the bucks and you have equal pressure in both tires. Use one line to do the rear.
That is a great idea they have.....I like it.....and the price is fair too.
My 2018 F3L comes with a small digital pressure gauge in the tool pouch (under the passenger seat). Never tried it, though, as I have a good analog gauge.
I use my portable slim tire inflator to check psi. It has a long enough hose to reach the rear tire valve. The brand is Slime and I purchased it at
Walmart about 7 years ago for under $20. Walmart has a similar looking one for $22.
I also agree that this sounds like a great idea ... unfortunately none of the "JT Machine Shop(s)" in my google search turned up anything like this. Nor could I find anything really on point on Amazon or elsewhere on google. The closest I could find were https://adventure-imports.com/product/indeflate/ which is ridiculously expensive, and this home-made tubing setup for off-road Jeeps that is designed to use with an onboard inflator (but wouldn't have to be): https://trail4runner.com/2018/05/06/...lation-system/. The latter seems about ideal if reduced to only two wheels, but naturally being lazy I looked for a similar commercial product and found none. There are lots of tires to help air up "duallies" but none to air up the front wheels equally at the same time ... unless someone here has a good idea.
Seems to me like it would be good to manufacture a commercial product to air up two wheels simultaneously to the exact same pressure. The market would not just be Spyders but all car owners could benefit. Connect the hoses to both front wheels or both back wheels and inflate and equalize them at the same time.
If anyone knows where/how to find such a product -- or has a link to the elusive JT Machine Shop, please let me know.
Hello all,
What are you all using for a accurate tire pressure gauge and where did you buy it from?
Thanks for your time and help!
P.W.
I use this one: TIRE GAUGE.jpg
It's made by Accu-Gage. I like it because I can keep it attached to the tire valve while inflating the tire.
I purchased it from BestRest Products. It comes in two flavors; straight chuck, or right angle chuck. https://bestrestproducts.com/shop/cy...-ez-air-gauge/
I made one myself. It was simple and cheap. Just buy the tubing, a "tee", two of the hose ends that clamp on your valve stems, and a fitting to connect to your compressor or hose. Piece of cake and a fraction of the cost. Works great every time
I have a couple of pressure gauges, and a tire filler with a gauge, from this seller, and I am very happy with the whole lot. I recommend this specific one for Spyders because the flexible hose makes checking the rear easier: https://smile.amazon.com/TireTek-Fle...-2-spons&psc=1
Hope this helps!
Bob
“There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
