Results 1 to 4 of 4
    Kansas
    Default ******** Parking Brake Lock Doesn't work on new Rally
    Yep, got the lock all installed and with the parking lever fully set the lock bolt hits the lever. It would appear CanAm had a redesign and didn't tell *********. I will send them an e-mail tonight but I would hold off on buying this because I now have a lock installed that won't function.
    Kansas
    """""UPDATE"""""", if you pull the lever out a little then the bolt will slip into the void. I assumed the bolt when on the outside of the lever. All is good now.
    Faribault, MN
    KC61, then the locking bolt is concealed by slipping in the void, how about a third pic with it engaged in this thread.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Kansas
    Hard to see in a pic with it engaged
