Rear wheel bearings
The F3 has 2 of the 6205 bearings. Are the RT's the same? BRP lists different part numbers but I suspect they are the same.
just curious why you would care? do you have a set of F3 bearings laying around and hoping you can use them, or....
No...thats not it. My F3 had oem made in china bearings. I replaced them with NTN Bearing 6205ZZC3/EM Single Row Deep Groove Radial Ball Bearing, Electric Motor Quality. This 100% fixed the gear whine type noise that some are complaining about between 40-50mph (70-80kmph). I dont have an RT but have friends who are complaining of the same issue and want to know if they can use the same without taking wheel apart first. It is a more expensive bearing but is US made, quiet running and a lot more quality.
All rear wheels 2008 to 2019, models GS, RS, ST, RT, F3 all use the same wheel bearings and seals. Even if BRPs part numbers change over time.
![](signaturepics/sigpic7798_4.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by billybovine
True. Many times the only difference in a BRP part # change is the supplier. I suppose quality might also be a factor. But the point being, the specs. are the same and the parts completely interchangeable. It is a mistake to assume that if the part # changes, the new will not interchange or be a replacement for the old.
![](signaturepics/sigpic963_3.gif)
A long time member of spyder ryders KC told me watch the tighting of the axle to tourqe when it comes to tire changes. Safe travels.
![Quote](images/misc/quote_icon.png) Originally Posted by dcarver
A little background would be nice. More torque, less torque? My spec is 155 to 177 Lb/Ft of torque. I tend to go on the lower end.
h0gr1der
![](https://www.spyderlovers.com/forums/maps/map.png?states=LA.MS.AL.GA.NM.AZ.CO.KS.OK.AR.TN.SC.NC.KY.IL.MO.IA.SD.WY.TX)
![Quote](images/misc/quote_icon.png) Originally Posted by rwill2cruz
Hey, I looked up that part number, it's a sheilded bearing, and I believe the Spyder uses double sealed. Is that correct?
h0gr1der
Yes. Works great. It is sealed bearing as well but not plastic seal
