Results 1 to 20 of 20
Thread: Gear lever
    Feb 2019
    England
    Default Gear lever
    Hi all ref Ryker F/R gear lever . I find it orkward to get my foot behind pedal to move it in reverse, as anyone made , or modified the reach of lever ? I don't think it can be adjust by removing it of spline as it as a flat with a bolt through it so stays in 1 position just a thought regards Nico 75
    Active Member bcraig's Avatar
    Grove City, OH USA
    Quote Originally Posted by Nico75 View Post
    I removed mine from the spline and rotated it to the rear a couple notches. That and repeated use makes it doable now.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    I pull mine into reverse with my hand and then push it into forward with my foot. There is an aftermarket company that is now selling an attachment that has actual finger grooves on the one side for just that reason.
    The way I look at it...it's reverse...how often do you really need to use it anyways? and how much of a bother is it to lean forward and pull it back with your hand?
    Just my thoughts
    Ft Pierce/Lk Placid
    If I know I'll need reverse whilst pulling in a parking spot, I'll stop & park with handlebar turned to the right for easy access (whilst still seated) to lever, and use HAND to go to reverse for when I come back. Piece of cake.
    Mar 2019
    Ky
    Too fat here, have to put parking brake on and lean pretty far off bike to reach it with my hand. Pretty comical when making a 9 point turn.
    Will need to rotate lever closer.
    Does anyone know if the aftermarket lever is actually longer, or if its just a grip change?
    Dec 2018
    NY
    I have difficulty placing in reverse using the toe area of my boot (short legs I guess) however no problems when I use the heel of my boot. Keeps my hand cleaner.
    Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
    Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
    2022 F3S, special series , Manta Green
    Ft Pierce/Lk Placid
    Quote Originally Posted by Jsmith8695 View Post
    Yes, I too found that heel works better than toe. But when riding with flip flops, neither works.
    Dec 2018
    Peculiar, Missouri
    Markubis - I agree 100% with you!! My wife is 5'2" at 110 lbs. She can put her Ryker in reverse with her foot. Depends on the shoes she has on. I can't do that.
    Grove City, OH USA
    I rotated the shifting rod down a couple notches on the spline and it made it easier to reach with my toe. A lot of new Ryker owners try to pull straight back, which doesn't work. It's a rotating down action. If you rotate the lever down a couple notches, it becomes more of a rotating back action.
    Mar 2019
    Elizabethtown Pa.
    Quote Originally Posted by Markubis View Post
    Just my thoughts
    I totally agree. I do the same.
    Oct 2015
    miNNESota
    MAuxoad%S9ysh99sZYxHCw.jpg********* has a huge new lever to adapt to your Ryker for easier use.
    2019 900 Rally , Black
    Mar 2019
    Ky
    Quote Originally Posted by vstrommer View Post
    A new lever is whats needed, but I’m pretty sure this accessory is simply a handle. Doesn’t address the problem.
    Jun 2011
    Alamogordo, NM
    Quote Originally Posted by Aufgeblassen47 View Post
    Riding with Flip Flops.............You are kidding........One would hope.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Mar 2019
    Ky
    Someone did a great mod on the FB Ryker forum, her husband welded an extension to the existing shift lever that brings it a few inches closer to the rear of the bike and softens the angle. They posted a video but not from you tube, I took a few still photos in freeze frame. If anyone is interested I’ll try to upload a couple.
    Sep 2018
    Orillia Ontario
    I repositioned mine back 2 notches, huge difference, very easy to hook your toe for reverse.
    2019 F3S , Blue
    Feb 2019
    England
    Default Gear lever
    Hi bcraig just an update on reverse leaver . I bought a bike gear lever from Amazon £ 10 , cut the end off which toe goes under , drilled hole through gear arm , ordered another gear rubber from dealer , which matches original Ryker one and passed a dome headed bolt through the rubber , locknut on engine side . Now it matches the Ryker one and looks like it's a BRP part AND it works , I can reach it no problem. Regards Nico 75 forgot to say take existing rubber off and put new lever ( must be 11 MM ) on to Brp lever angle how you like , then thighen Allen bolt wish I could pics on but still struggling
    Jun 2012
    Nevada
    Jul 2019
    CO
    Feb 2019
    England
    Hi Jerryturner yes that's the one I bought and like I said I cut off the end and drilled hole to take bolt which passes through matching BRp rubber ( dealer ) i think it's worth the effort to do an looks factory regards Nico 75
    Jul 2019
    CO
    I like it a lot. It was annoying to have to keep reaching out to go into reverse. I think it's worth it to do. It was a cheap fix and was easy to do. I didn't drill anything when I did mine but I still it looks good.
