Results 1 to 25 of 30
Thread: Park brake
    Nov 2015
    Nebraska
    Default Park brake
    I have a 2017 SE6, it’s in the shop because the park brake wouldn’t release. From what I’ve read on here, that’s a problem that RTs have. No telling when I’ll get it back, I took it in last Tuesday, so it’s been over a week now, and I just called today and they said it would be next week before they got a chance to look at it. It’s intermittent, so hopefully it’s still doing it when they do get to look at it. My question is, has anyone ever modified anything, so it isn’t needed ? If I had a manual I would just lease it in gear and not use it. Why couldn’t you make some sorta way to use the foot brake and lock it down to hold the bike ? I’d think that would work someway or another. Once they say they have it fixed, there’s no guarantee they do, or it won’t happen again. I can just see being 300 miles away, and it does it again. What’s everyone’s thought on trying to get something like that to work ? Thanks, sorry so long, I wanna ride again someday
    Apr 2014
    Beloit Kansas
    your's is a cautionary tale. I know there is a way to release a cable or something to take the
    parking brake off line, and I better learn how to do it, before this issue crops up with me.
    Jul 2010
    Las Vegas, NV
    Keep 2 12mm open end wrenches in the bike, along with small wheel chocks. Under the muffler on the wheel is a cable that goes to the caliper. Loosen the nuts that hold the cable, remove cable from caliper, bike is free. Use wheel chocks to prevent rolling.
    Joe Meyer
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    I had the same thing happen to me. It was intermittent at first and after fiddling with the switch it would release, and then it left me in parking lot and would not release, did as explained above and rode for a week just chalking the tires while waiting to take it to the dealer. Switch was replaced no further problems.
    To be continued....
    Nov 2015
    Nebraska
    I released the cable so I could move it and ride it to fixit shop. Guess beanst it happened once, Ima little gun shy. Thanks
    The problem is going to most likely be one of two things, the switch or the parking brake motor. If it's intermittent I'd cast my vote for the switch. I would not paint too many RTs with a big brush that gets the whole model line; most DO NOT have the problem. I had my parking brake motor replaced under warranty because it would not hold once set. Follow Joe Meyer's instructions until the dealer finds the cause of the problem. Yes, you could do the simplest modification if you wanted to remove a few body panels, remove the brake cable and use a wheel chock, IMO a less than brilliant idea.
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    Just had this happen to my 18 RTL with 700 miles on it during Bike week here in Myrtle Beach. I was parked off the main drag(rt. 17) shooting the breeze with a friend. Hopped on Gracie and pushed the brake button. The red brake light on the dash stared flashing and she put a death grip on the rear wheel. Turned the ignition on and off several times to no avail. Checked for a fault code and got 3 of them listed. P0571, P1571 and U0128.(BTW, couldn't find any of these in my downloaded service manual) Couldn't move her. I called my dealer and spoke to service and they admitted there was a history of the right switch cluster failing. They could not come out to me at this time, but they told me a way to free the rear wheel by using a procedure similar to cptjam above. I checked the OEM tool kit for the 12mm wrenches. NOT! they don't include any in our kit. Luckily a guy stopped by while I was under her(damn that pavement was hot) and had an adjustable wrench(hate using them, but any port in a storm). The brake is located on the muffler side, can't miss it (2) 12mm nuts on a cable mounted on a steel bracket. Loosen the front nut first, then the cable mechanism will slide off the holding bracket. Bingo instant unfreeze. The red light stopped flashing and I road her without an e-brake the rest of the day parking her on level ground. (Shop said it was OK to do this, would not harm the bike or void the warranty). Long story short, got her in my home garage and slid the cable back on the bracket. adjusted and tightened both nuts lightly and she's working again. The fault codes have also disappeared from the dash. Not sure if it was a needed cable adjustment or a faulty switch/button, only time will tell) I'm still gonna bring her to the dealer next week...…………... no guarantees it won't happen again. Oh, and I now have (2) 12mm wrenched added to my tool kit.
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    May 2018
    Murrells Inlet, SC
    Correction......meant to say Left switch cluster not right.
    Nov 2013
    Central Texas
    I have the same problem. Was going to ride the Spyder to work today, and bingo, parking brake would not release. Now my question is, since the brake won't release, how the heck am I going to get it out of my garage and up onto a flatbed to have it taken to a dealer? I guess I could try the method that cptjam suggested, but fear I would get into a warranty hassle with BRP. After all the troubles that I had with my 2013 RTL, I'm getting a bad feeling. BTW, no codes.
    May 2018
    Chateauguay, Qc, Canada
    Check post #3 and #7.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    May 2018
    Tucson AZ
    I posted before on this subject because it has been an issue from time to time for myself, and a bit more exclamation is in order. First of all, ALWAYS, ALWAYS, ALWAYS put your foot on the brake pedal whenever you DO ANYTHING !!!! I can't begin to say why, but it seems to make a difference and keep the brake lock deal at bay. This routine has worked for me a couple of times, when the brake locks up, turn OFF the key and let the warning beeper do it's thing which takes about 15 seconds and it will stop, then turn the key back on and do the start process and remember to keep your foot on the brake pedal. This has worked for me before, and now I ALWAYS keep my foot on the brake pedal which does the trick, mostly.... If your having the issue consistently, take it to the shop and wait. BTW, there are no error codes which come up with this brake issue????
    2017 RT , White
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    Ok It happen to me today on my 2019 f3s special series with 412 miles on it, good advise to Carrie 2 12mm open ends ,work like a charm will go to dealer tomorrow and make a appointment to have it fixed. the manual brake worked great on my 2014 rss, why fix what is not broken
    richie spyder
    May 2018
    Murrells Inlet, SC
    Yes, fault codes P0571, P1571 and U0128. all of which I couldn't find in my service manual. disappeared after I released and reset my brake cable.
    Nov 2015
    Nebraska
    I heard back from mechanic today. He said yesterday, the park brake release worked every time he tried it. This morning it worked fine, turned off RT, got lift set so they could put it on, and hook up buds, it wouldn’t release. Got it on lift, hooked up buds, he said it had so many codes, he’d never saw that many before. He said it seemed like only half the modules on motorcycle was throwing bad codes, and the others weren’t even working. Said he had called Can am, and was waiting to see what they said. He wondered if I had ever seen any codes pop up, I never had. Told him I did notice last summer right after I bought it, the park brake acted up just a little bit, and windshield didn’t go up or down. That went away after about a couple days, until park brake messed up this time. Does anyone have any ideas on here ? Do you think I should contact Can am, or wait and see what happens ? Thanks for all the help
    Active Member BUZZARD II's Avatar
    Dec 2016
    NoVA
    There's a new dealer in the NoVA area and I needed a new rear tire so I tried it out yesterday. Just being a tire change I suspect they gave the job to the shop mop.(junior man) Two hours later the service writer tells me my rear brake pads are very worn and I go take a look. OK put in some new ones. Taking much longer than expected I take a look into the shop. The tech. is stomping away on my brake. They tell me the parking brake is now stuck and they can't get it off the lift. Two more hours and they suspect it's the parking brake sensor. "We replace a lot of these" Well after more than six hours I have a new tire, pads and sensor.
    I will now carry two 12mm wrenches with me all the time. I will never go back to that dealer. Oh, my warranty expired, last month.
    Nov 2015
    Nebraska
    Default Park brake
    Ok, shop said computers not communicating with modules. BRP approved starting with left hand housing switch as possible fix. What and where is this ? Does it have anything to do with park brake ? Thanks
    Last edited by Peter Aawen; 05-20-2019 at 07:09 PM. Reason: Merged new thread into the rest of discussion on this problem
    The Left hand Housing is that left side hand-grip/switch gear, the one with the light hi-lo-flash button, the Eco/mode button etc..... There have been a fair few 'failed' L/Hand units, and if they go it can cause all sorts of problems for the Spyder. So it's probably a good place to start!
    Thinking about this a bit more, where's your Park Brake switch, Marr?
    Apr 2013
    massapequa ny 11758
    My 2019 f3s lock up in park did release with the 2 12mm wrench went to the dealer he try it and it is working now whats up
    richie spyder
    Nov 2015
    Nebraska
    I think my ordeal is about over. Talked to mechanic, they got left hand housing replaced, and finally had to order a new ecu. Today, he said everything checked out good finally. Said park brake and everything was working. Hoped all this had fixed park brake problem. As long as it was working there was no check, so hopefully all’s good..said he would call in a couple hours as soon as he got it all back together and test ride it. I was a happy camper, been over 3 weeks. About 3 hrs later he called, said we got some good and some bad news. Bad is I would have to wait to pick it up, good was park brake wouldn’t unlock when he went to test ride it. With everything working now, he could hook buds up and figure it out. Wound up being the park brake motor. He said switch worked fine, took motor out hooked it directly to a battery and it wouldn’t go either way. He overnighted a new one, hope it gets here tomorrow. I would have got it home today and park brake would have screwed up in a day or 2 and I’d a
    Nov 2015
    Nebraska
    Got cut off, had a stroke. Thanks everyone for all the help.
    Active Member FalconAF's Avatar
    Mar 2019
    North Las Vegas, NV, Third Rock From The Sun
    My 8-week old 2018 RTL parking brake wouldn't release for the first time 2 days ago in a parking lot. It finally released after turning off/on the key and recycling through the digital dash startup 4 times. I already had an appointment scheduled for yesterday at my dealer for the 3000 miles service and mentioned it to them. They did the service and told me they were ordering a new parking brake motor under warranty. If it arrives before my road trip in a few weeks it will be replaced before the trip. In any case I'll be carrying 2 of the 12mm open end wrenches and a couple small wheel chocks with me from now on. Thanks for that info. So far, it hasn't happened again, but...…
    Quick question about this -> "The brake is located on the muffler side, can't miss it (2) 12mm nuts on a cable mounted on a steel bracket. Loosen the front nut first, then the cable mechanism will slide off the holding bracket. Bingo instant unfreeze."
    What happens when "...the cable mechanism will slide off the holding bracket."? Is it still attached to the bike? Can I just ride with it that way after "loosening the front nut"? Or is something hanging down I need to secure after the "slide off the holding bracket" thing? Are parts gonna fall off if I don't? I have no clue right now.
    2018 Spyder RT Limited
    Jul 2010
    Las Vegas, NV
    Rick, you could put the cable right back in its holder, just leave the end disconnected. I can show you the next time I see you. Joe
    Joe Meyer
    Mar 2019
    OK, I crawled on my garage floor (I'm really getting too old for that kinda stuff ) and took a look. So are you saying that I would loosen the front nut first, THEN the back nut ALSO, then just slide the cable out of the caliper (towards the front of the bike), then just retighten both the nuts without the cable itself in the caliper anymore?
    If that's it, in an "emergency" I could probably do that without setting my RT on fire or something. No guarantees, but probably....
    Nov 2013
    Central Texas
    Spoke with my dealer yesterday. My parking brake problem is the motor with the pulley on it that moves the parking brake cable. He also told me that he had another 2017 RTS SE6 in his shop with the exact same problem that needed the exact same part. Anybody seeing a trend here?
    Apr 2018
    Corpus Christi Texas
    When your parking brake fails and just blink, check the Fault Code, under Setting. If you see U0128, before doing anything else, open the seat and make sure the seat sensor cable is plugged in properly. This exact thing happen to me 2 days ago and it was the seat sensor somehow being unplugged (I know why, but I'll pass on that, no not me). Code U0128 states that a seat sensor wire may have been cut off or disconnected. among other things. I called 3 dealer for help, they had no idea. But keeping 2 12mm wrenches is not a bad idea.
