Results 1 to 21 of 21
    Active Member LifeLongRider's Avatar
    Aug 2018
    Florida
    Default LED Headlight Kit - Has Anyone Used This Kit ?
    Saw this LED headlight kit on Ebay for $64.95 and was wondering if any of the lighting gurus on this forum were familiar with it. I've thought about the Lamonster kit but am generally unhappy with some of the reviews I've read, mainly to do with the lighting pattern of the OEM reflectors not being real compatible with LED bulbs. Not sure if it's worth making the change. Anyone have any knowledge of this particular LED kit?
    2019 F3 Limited
    2019 F3 Limited , Oxford Blue
    Jun 2010
    Las Vegas
    They have a 60 day return policy so if it won’t cost anything to try it why not go for it?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jan 2019
    Kentucky
    I too have been looking for LED Bulbs for my 2015 F3 S. These are also adjustable by rotating the bulb in the fixture giving you the correct light pattern.
    Clovis, CA
    That looks just like the kit Lamonster sells. Oops sorry Lamonster.
    2015 F3S-T , Black Black & Black
    I would look for something made by " Phillips Ultinon " ….. very high quality stuff …...jmho …. Mike
    Jul 2018
    New Jersey
    LifeLongRider, from what I understand if the reflector is not compatible you will not get good lighting down the road. Which is my problem with the Lamonsters, also why am looking into driving lights.
    Joe
    2018 F3L , Blue
    Feb 2019
    Portland, Oregon
    Appears the lighting elements are on the sides only and create a "different" pattern than that of the original halogen bulbs. The maker of the Arc fog lights has a 360* element LED upgrade that promises a better pattern. Those are the ones I would go with.
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    I just got 4 sided LED lights on eBay for $21. They work great and light up the road much better than the OEM halogens. I don't think it matters which ones you get. The last ones in my wife's F3S were in there for almost two years without issues. We traded that one and I put the 4 sided LEDs in her new F3L.
    Aug 2018
    Florida
    Quote Originally Posted by bscrive View Post
    BSCRIVE - thanks for the tip. I wasn't aware of the 4 sided H4 LED's but will certainly look into it.
    2019 F3 Limited
    Active Member ChicagoSpyder's Avatar
    Chicago
    bscrive, do you have a link to the lamps you bought? I ask because what you have works, and not all 4 sided LED's will work as well as yours do.
    2018 F3 Limited , Black/Chrome
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    I also installed the 4 sided H4 led bulbs. They are the 4 sided ones and work great.
    USMC RETIRED
    BLUE KNIGHTS NYV
    2022 F3T Glacier Blue
    Mar 2017
    I'm happy with mine. They have filaments in the correct position to mimic the Halogen filament which work well with the prisms inside our assembly. Going with 4 sided may disturb your opposing traffic because the beam will not be focused. You will get light flickers at you
    This is important …. does your radio get the same reception …… I ask because LED's have caused problem,s with reception the first pair I got fromT*****d had the reception issue the ones He now sells doesn't ……. but they are about $99.00 ………...Thanks … Mike
    Active Member deer30084's Avatar
    Tallahassee, FL
    I have Lamonster's. They are ok, but I did a test with my wife driving towards me at night. She said they were too bright. Other oncoming traffic did not flash their lights at me, so I don't know. I shined the lights on the garage door. Seems to be some stray light. Knowing what I know now from reading, YOU SHOULD NOT PUT LEDS IN HALOGEN HOUSINGS. Read those capital lettered words 3 times and let it sink in. LED's need special projectors. I will never put LEDs in Halogen housings again.
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
    Nov 2012
    Ottawa, Ontario
    No problems with the ones I bought for my wife.
    Chicago
    Are you going to share with the class what lamps you used on your wife's machine or will it remain a mystery?
    Aug 2018
    Florida
    I've attached a picture of the r/h headlight reflector on my F3 Ltd. I see that light is reflected forward from both sides of the reflector but not from the top or bottom. The top side appears to be a "diffuser" and there is no reflective surface on the bottom side what-so-ever. I conclude that due to this design, four-sided LED's would add very little other than to appear brighter and would add even less to "down-the-road" lighting. But then the Halogen bulbs are 360's so who knows. I've decided to go with the two-sided LED kit as pictured in my opening post (which are pre-clocked left and right). I'll give them a try and post the results. I agree that the use of LED headlights would benefit greatly from reflectors designed specifically for LED bulbs but BRP just isn't up to speed yet on LED headlamps for the Spyder line. Maybe the next generation will have them.
    2019 F3 Limited
    Nov 2012
    Ottawa, Ontario
    Quote Originally Posted by ChicagoSpyder View Post
    PM'd you.
    Chicago
    PM'd you.
    Thanks!!
    Jan 2019
    Kentucky
    I just installed a set of the Genssi bulbs. Just need to make sure the LED'S are clocked so that they shine to both sides. These easily adjust just follow included instructions. LED'S need to shine to the sides of the reflectors.
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
