Results 1 to 23 of 23
    Feb 2019
    England
    Default Nico 75 - Ryker knee pads
    Hi all as anyone fitted the BRP knee pads WITHOUT taking any panels off? If so is it easy. Regards Nico 75
    Feb 2019
    Clearwater, FL
    Based on BRP's installation video, it looks to be very easy.
    Mar 2019
    FL
    Do the knee pads help anything i.e. comfort? What is that secondary piece that has an attachment point on the inside?
    Feb 2019
    England
    Hi all ref knee pads I think it's a " belt and braces thing " ( the ring fitting at back ) regards Nico 75
    Ft Pierce/Lk Placid
    What's the actual point of them?
    Feb 2019
    England
    Hi all ref knee pads I think they are more comfortable for your knees than HARD plastic must be better regards Nico 75
    Ft Pierce/Lk Placid
    Quote Originally Posted by Nico75 View Post
    But my knees are in open air whilst ryding my Ryker, so pads will make no difference!
    Norman OK
    Yes: I've put them on (easily--no panel removal needed), & they do provide a good surface for knee-gripping while turning at speed.
    Feb 2019
    England
    Hi aufgeblassen47 try keeping your knees open on fast tight corners , instinct puts your knees onto the plastic regards Nico 75
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Quote Originally Posted by Aufgeblassen47 View Post
    When you're going around corners, try hugging the Ryker with your knees. You will feel more planted in the seat. The downfall to that is the insides of your knees can get sore due to the hard plastic.
    Ft Pierce/Lk Placid
    Never had that problem. Simply going slower on the corners works.
    Dec 2018
    Peculiar, Missouri
    All I have to say is for $100 my knees work just fine!!!
    Feb 2019
    England
    Hi mikeyuberalles ref knee pads. Video shows panel removal which I didn't do to much trouble just for pads. Regards Nico 75
    Ft Pierce/Lk Placid
    Quote Originally Posted by graysonsway View Post
    A hundred bucks?! Sheesh!
    Jan 2018
    NH
    I'm surprised that no one has come out with a knee pad that was just an adhesive add on for the side knee panels. I would think something like that would work well.
    Feb 2019
    England
    Hi Markubis ref tank knee pads , try Universal Stompgrips and cut to your shape cost around £ 25 it you want to go that way. Ryker " tank " is unique shape regards Nico 75
    Mar 2019
    Ruidoso Downs, New Mexico
    Why would you want to got THAT slow on the corners?! I'm not going to shell out $100 for them but would like to figure out something (we have lots of curves in the TX Hill Country and we ride em like we stole em!)
    2020 F3L; gone but not forgotten are all the good miles!
    Florida Swamp
    Quote Originally Posted by Markubis View Post
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    $16.00
    Raised rubber bumps on the surface make gripping with knees easy. Simple 3M peel and stick adhesive. Intallation time 5 minutes each. No panel removal required.
    2019 F3-S , Black & Silver
    Active Member poli's Avatar
    Feb 2019
    East Texas
    Just a heads up, I put a vinyl pink cancer awareness angel on my Spyder and when I tried it on my Ryker it wouldn't stick to the matte black panels!
    Spyder F3-S Special Series my traveling ride
    Ryker Rally modified for dual sport duty
    Honda Grom heavily modified for dual sport duty
    Ducati Scrambler Icon Dark my other traveling ride
    Chattanooga TN
    Thats installed on an F3. Got any pics on a Ryker ?
    Florida Swamp
    Quote Originally Posted by cjackg View Post
    Don't have a Ryker or know anybody that does. I could go out and measure the pads I put on the Spyder if it would help.
    Dec 2018
    NV
    I installed them, without removing panels, just a little tedious getting everything aligned. As for the point of them, the heat shielding is pretty nice (I live in the desert), but I find the added grip for your knees while maneuvering at speed is the real plus. The hard plastic gives you no real grip
    Jun 2019
    Burton on Trent, England
    I’ve just received some Eazi-Grips Silicone Universal.
    Two 30x15 cm sheets that obviously can be cut to whatever you want.
    They come in a charcoal colour (ideal)
    UK website at eazi-grip.com , they come in at £32 so around $40.
    Will be fitting in the next day or so.
