Results 1 to 7 of 7
Thread: Rear Tire
    May 2016
    Ontario, Canada
    Default Rear Tire
    Hi Folks,
    After many replies to my question on "front" tires I will be getting Continentals installed for the front. (Based on availability)
    Now my question(s) are;
    1) Best or most bought tire for the rear?
    and
    2) Does anybody know of a Spyder dealer that will sell "and" install a rear "car" tire. Will travel to the USA if required to get done. Prefer upstate NY area (Buffalo, etc) if possible. From what I've delt with none of the southern Ontario dealers will deviate from OEM. Heck, my dealer even gave me a hard time over using Amsoil 10w-40 bike oil.
    Thank you in advance for all the info and help in this matter and the advice on the front tires.
    As a note - "man I hate those OEM tires, just won't balance out."
    May 2013
    Edmonton Alberta, Canada
    Toyo Proxes 4
    Great tire & available in Canada
    https://www.tireland.ca/en/search-ti...ire-allsearch#
    As for finding a BRP dealer to put a car tire on I wish you luck but don't keep your hopes up.
    Might suggest to check shops in your area that specialize in trikes as they may be able to help you out.
    2014 RT-Ltd , Cognac
    Jan 2015
    southern WI
    I've liked the General Altimax for the rear tire. I've ordered them online and had my local shop guy mount each time. I highly doubt you'll ever find a CanAm dealer willing to order and install a car tire on a Spyder.
    2016 RTS , Pearl White
    Apr 2017
    North Central Florida
    Quote Originally Posted by johnny canuck View Post
    USE the BRP web site and the PHONE to canvas dealers nearby.
    So far I have found maybe one or two out of 10 dealers that will install whatever tires you bring them if they fit but NONE that actually sell the small car tires that are needed.
    I am still calling around Central Florida.
    Mar 2013
    Sent you a PM.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    ...Does anybody know of a Spyder dealer that will sell "and" install a rear "car" tire...
    Quote Originally Posted by Purple Guy View Post
    Toyo Proxes 4
    Not sure where you are (Ontario is huge) but the Toyo Proxies 4 is quite popular in Canada and readily available. As you found out you won't get much help from any BRP dealers.
    Call Port Perry Automotive 905-985-1999
    They can supply and install/balance a tire for you. Toyo or Yokohama and others.
    The owner has an RT and has the balancer that will fit Spyder rims.
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    Vermont
    Hi Folks,
    and
    HI, I am running the Continentals Contiprocontact's ( Size: 165/60R 15 ) on the front, these were installed on 6/24/2016 at a dealership in Vermont. I am running them at 19PSI.
    On the rear I am running General Altimax RT43 (Size: 215/60 R15) @ 26PSI. My 2nd General Altimax RT43 tire was installed in March of this year. The spyder has 24,553 miles. I like the General because it has the " REPLACE TIRE " in the tire it. The ratings are excellent. I have a 2014RTS-SE6.
    I can help you with a dealership in upstate New York. I am sure someone will chime in with the info.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
