Results 1 to 16 of 16
    Kansas
    Default Very Informative Video
    This is the most informative video I have found on the Ryker
    https://www.youtube.com/watch?v=xOnk9bxqdPE
    Aug 2018
    Columbus
    thanks for posting this
    Kansas
    It looks like the guy is a Can Am rep educating the dealer is kinda the way I see it.
    Active Member njfishfan's Avatar
    Dec 2018
    New Jersey
    He stated 25 psi for front tires...my label says 20 psi for front tires ....which is correct ?
    Kansas
    He is showing the Rally so it may be different tire pressure but go by what the label says for your particular model.
    Dec 2018
    New Jersey
    Quote Originally Posted by KC61 View Post
    I also have a rally...and will stick to what label says
    Kansas
    Man, 20 psi seems low but what do I know.
    Active Member poli's Avatar
    Feb 2019
    East Texas
    Go by your label. He was wrong on a couple of things.
    Spyder F3-S Special Series my traveling ride
    Ryker Rally modified for dual sport duty
    Honda Grom heavily modified for dual sport duty
    Ducati Scrambler Icon Dark my other traveling ride
    NorCal - Northbay
    To put it in perspective.... I run 18 F&R on my F3-S with car tires and it is pure awesomeness! The OE Kendas were labeled to run at 15-17 on the fronts.
    Chuck
    Mar 2019
    Ruidoso Downs, New Mexico
    Quote Originally Posted by poli View Post
    Such as?
    Aug 2018
    Thousand Islands
    He must be wrong on mpg mid 20's if you push it hard ?
    Feb 2019
    East Texas
    He stated that sport mode shuts off traction control. Rally mode shuts it off but my experience, sport just delays it before cutting in. That plus the tire pressure issue. I did learn about the reaching under and lifting on the brake reservoir to assist in moving the right foot peg though.
    Mar 2019
    I wondered about that. It was my understanding that Sport mode just 'relaxed' traction control as well. The brake reservoir trick is one worth remembering! I thought it was interesting that he mentioned how easy it was to remove the body for access to the engine but did not demonstrate it; guess that was in the instructions for the mechanic! I suspect it won't be long before I figure it out though.
    Mar 2019
    Oviedo, FL
    Guys, tire pressure recommendations are on the inside of the service panel on the right side of your trike. Just twist the ring and open the tab. It’s on a sticker affixed to the panel door.
    Mar 2019
    Oregon
    Thanks for the video link; I learned a couple of things...
    FWIW, the label on the bike states 20 PSI for the fronts and 28 - 30 PSI for the back, not 25...
    I know this because I just topped them off. I have mine scheduled for repairs to fix a front/left leaking tire. There's no visible nails or holes, so it's likely a bead or stem issue...
