Results 1 to 14 of 14
    Pennsylvania
    Default F3L won't start...checking everything I can think of
    Ok issues with 17F3 L..went to start it up everything is normal till I hit start...bam no power anywhere at first. Checked all fuses...all good...I just checked the battery terminals tightened them up...is there another ground I may need to check ? Tried it same thing ...battery on charger right now
    Bryant, Arkansas
    1 - Look at your kill switch ( red button on right handlebar). Should be in DOWN position.
    2 - Make sure your foot is on the brake when you hit starter, (Might have shut off in gear).
    Let us know
    Cruzr Joe
    Pennsylvania
    Kill switch was one of the first things I checked. It's odd goes thru all it process then I hit mode then start ...shuts right back down...lights start flickering and you can hear it going thru a system start up...gauges going up and down screen looks like it's in a start up mode also ?
    Have it on the charger was told could be a low battery...when I try next time I will hold the break just in case
    Apr 2017
    North Central Florida
    Quote Originally Posted by esmith3190 View Post
    What do you mean "at first" ?
    Yes, you need to check the OTHER END both main power cables; one goes to ground.
    You REALLY NEED a voltmeter to chase down the problem.
    If absolutely everything really went dead........then the kill switch and brake aren't going to be the fix.
    Bryant, Arkansas
    Really sounds like a battery failure or poor battery connection.
    Cruzr Joe
    Pennsylvania
    Tightened all terminals...Frame ground also tightened found it behind the front trunk bolt going into the frame..it was tight.
    Pennsylvania
    I just had it out last weekend...No issues at all..had it on trickle charger all winter long..?? Also talked to the mechanic at the dealer ..checked everything he said. Is there another ground somewhere.. 2017 F3 Limited
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    Looks like it is your battery. Just because it is only 2 years old doesn't mean that it has not gone bad. Try putting a battery pack on it and see if it will start.
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    I'm also guessing it's the battery gone bad or needs a good saturation charge.
    Joe
    2023 F3
    Default Ouch... Battery
    You mention it was on a trickle charger all winter long...not good you should only use a maintainer, like a battery tender. Quickest check will be to hook up to a known good battery, if a car don't start it up, and see if you can fire her up. If so it will be the battery and you will have to have it checked or replaced as needed. Hoping a good charge will get you going but your gonna have doubts ...
    Pennsylvania
    I got the neighbor's jump pack...started right up. Thank you all new battery time.
    Apr 2017
    AND.....you then need to check your "trickle charger"......and replace it if it is not a smart battery tender/maintainer.
    If you blindly continue to use that charger without first checking the voltage........that would NOT be a wise thing to do.
    And if it really is a "dumb" trickle charger, continuing to use it would not be a wise thing to do either.
    Harrington, Australia
    Yes, it’s often just semantics, Easy Rider....so many people call their battery tender a trickle charger.....very confusing.
    HeliBars Handlebars
    Kenda Kanine rear.
    Pennsylvania
    Well...been awhile .I put the battery on a charger. 12.8 reading out of the bike. Installed battery ...same issue getting new battery and then having charging system checked...same tender I used on my 2013 never had issues before
