F3-S coolant
Went to two auto part stores today to find some coolant for my wifes 2015 Spyder F3-S. The manual says to use BRP long life coolant but I am not driving an hour and a half to the can-am dealer. It also says "or coolant designed for aluminum engines". Both of the popular auto stores didn't have anything and they said that I would probably have to go to the dealer. What coolant do you guys run in the 1330? The bike currently has the orange coolant and I just need to top it up. I couldn't believe the stores didn't have a coolant for aluminum engines. Thanks.
Most auto engines are aluminum I thought nowadays
Instead of driving to the dealer an hour and a half just order it online from a dealer since you only need to "top it up"
Probably time to drain, flush F3 radiator system on 2015 F3 Spyder.
Then you can install ICE Coolant, for Aluminum & all engines.
https://engineice.com/faqs/
https://www.amazon.com/Engine-Ice-TY...01614OJGE?th=1
Jim
Originally Posted by JayBros
Page 91 of the maintenance schedule in your operator's guide says to replace the coolant every 28,000 miles or five years, whichever comes first. You are also supposed to dilute the coolant 50:50 with distilled water.
I know this. Why are you quoting the manual?
