Page 1 of 6 12345 ... LastLast
Results 1 to 25 of 139
    Jan 2019
    North Carolina
    Default Wheels falling off?
    Have folks seen this YT video?
    https://www.youtube.com/watch?v=piJ_iEJGaH8
    Seems pretty scary and possibly life threatening if your wheel falls off at high speed, right?
    Thoughts on this? Anyone seeing this on their Ryker's wheels?
    2019 Can-Am Ryker 900 RE
    2019 900 Rally Edition , Black w/Yellow Panels
    Active Member poli's Avatar
    Feb 2019
    East Texas
    Your wheels are NOT going to fall off! IF the nut happens to loosen up, the red clip keeps it from coming off. The 3 pins he's talking about have absolutely nothing to do with the wheel possibly coming off. They are pressed into the wheel and they normally stick about 1/4" past the brake disc. Their only purpose is to connect the wheel to the brake disc (the brake disc has 3 holes they fit into). Without them the brake disc would just spin. So if they should happen to come out, you would just have no brakes on that wheel (but you have 2 other brakes so you could have time to stop). Where he shows them "backing out" is normal.
    Spyder F3-S Special Series my traveling ride
    Ryker Rally modified for dual sport duty
    Honda Grom heavily modified for dual sport duty
    Ducati Scrambler Icon Dark my other traveling ride
    Jan 2019
    North Carolina
    Quote Originally Posted by poli View Post
    That's not what he claimed in his first video: https://www.youtube.com/watch?v=HMmfHc2QJhg&t=53s
    Anyways, I'm interested to find out what his dealer ends up doing. Might be useful info for the knowledgebase.
    I didn't watch his 1st video. Looks to be a lot of language there and I don't really need that. But in his 2nd video he says his right well 'Fell Off' and the left wheel is 'Falling Off'. If his wheel fell off it would do a lot of damage to the rotor and most likely the right front corner of his Ryker would also have hit the ground. Not to mention likely damage to the hub threads and how in the world would you ever find the hub nut with a wheel coming off at 80 mph? So I'm a bit confused as to whether he only thinks his right wheel was falling off. Or if it actually fell off. I'm thinking not.
    I agree with Poli. Even if all 3 pins fell out, it should not cause the wheel to fall off. The function of the pins is to mate the wheel to the rotor. Not to keep the wheel on the hub. Completely unrelated as far as I can see.
    I have checked all 3 pins on each side of my Ryker. Each one is protruding exactly the same as the one this guy pictures in his video as (backing out). So I do not think he has the problem on the left side that he things he has.
    I don't disagree that he may have a serious problem. But I think he may be completely mis-diagnosing what is wrong with his Ryker.
    It is easy to go sideways when something goes wrong with your brand new vehicle, or with a product that you just installed. But it is much better to think first than to blow up first. We had a saying in the fire service. 'There is always time to panic later'. Saves a lot of apogees and egg on the face. We've all done it and I am not without fault in this regard myself. So not throwing stones here. Just saying.
    I hope he gets this fixed and we all find out what really happened here.
    BajaRons@BajaRons.com
    423-609-7588
    Feb 2019
    East Texas
    After watching the first video, I agree with him -- dealer issue NOT BRP. He states the clip come off. As I said in my response, that allows the nut to come off. Just don't know how that clip come off. Also, looking at the wheel, all three pins are missing and the brake disc is chewed up. Again, don't know how they could have come out. Looks to me like the dealer didn't line up the pins to the disc properly and probably didn't torque his wheels correctly either. Properly torqued, that nut should never move, with the clip being a backup. I firmly believe the idea behind the whole system is solid. But it is a good idea to have the dealer torque them while you watch.
    Inactive User
    May 2018
    MN
    Isn't the guy saying he suspects not torqued properly? Finding out the source of the problem is crucial at this point.
    Mar 2018
    Ontario ,way up north
    If someone did not line the wheel up with the pins would it not push the pins out when torquing the wheel ?
    2018 RTL , dark blue
    If the dealer did not line up the pins with the rotor. Wouldn't that push the pins back through the wheel when tightened?
    I think you're probably right. This is likely going to end up being a dealer assembly issue. I think the design is sound.
    423-609-7588
    Jan 2019
    Charles Town, WV
    Probably comes down to dealer not tightening the wheel nut properly. When braking the loose wheel would move back and forth on the pins causing them to come loose from the wheel.
    Inactive User
    May 2018
    MN
    Jun 2015
    Ritzville, Wa
    Default Wheels falling off??????????????
    Greg Kamer
    "It's better to be not riding and wishing you were; than to be riding and wishing you weren't!"
    USAF, 20 years, retired
    Sadly passed away in December '23. Still helping the SpyderLovers Community, but no longer posting. Greatly Missed.
    https://www.spyderlovers.com/forums/...er-Member-here
    2018 Can Am Spyder RT-Limited
    Houston
    This is most likely an assembly or service issue. IE the wheel attachment nut not properly torqued and backed off.
    Just FYI, if you do not align the pins to the rotor, there is not sufficient threads on the hub for the nut and clip to go back on. At least not without doing other damage by forcing something to break.
    His pins came out from the wheel wallowing on the hub after the nut came loose. He will need a new hub, rotor, wheel, spacer, nut and clip. His dealer is playing CYA so as not to be on the hook for this.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Exactly what I think as well. It will be interesting to see how close you are to reality. I think we have a bad assembly here. I also wonder how the dealer will spin this. But I'd say BRP is aware of the video and I don't think this will just go away for that dealership.
    423-609-7588
    Jan 2019
    North Carolina
    Another update from yesterday.
    https://www.youtube.com/watch?v=7kH1Mxw9wIs
    From the video: The dealer says, "we don't know", BRP saying "we don't know"??? Even if it is the dealer...at this point for those of us with the vehicle in hand. What in the heck am I supposed to be looking for before I decide to take out the bike?
    Active Member Dragracer's Avatar
    Oct 2009
    Lecanto, FL.
    This gentleman need learn the correct terminology before posting. From http://www.rfsystemlab.us/glossary/stator/
    stator
    stey-ter
    noun
    Definition
    Stators are the stationary part of an Alternator, while the Flywheel is the moving part that helps generate a charge. Almost like what you would see on a bicycle tire, Stators have multiple “spokes” that extend from the center. These “spokes” are usually constructed out of a number of thin iron plates stacked on top of one another. At the end of these “spokes”, is a form of a magnet wire (usually copper). As the Flywheel (the non-stationary part of an Alternator) moves around the Stator, the permanent magnetics on the Flywheel generate AC power which is conducted through the copper wire on the Stator, and often times the AC power is sent to a Rectifier which will convert the Alternating Current (AC) to Direct Current (DC) to power electrical systems that require Direct Current.
    Also from https://www.aviationpros.com/engines...-and-operation
    What is a stator in a jet engine?
    An axial flow compressor has two basic elements - a rotor and a stator. ... After the air is impelled by the rotor blades, it goes through the stator blades. The stator blades are fixed and act as diffusers at each stage. They partially convert high velocity air into high pressure.
    Calling an illegal immigrant an undocumented worker, is like calling the corner drug dealer an unlicensed Pharmacist.
    2019 900 ACE , Stock Black
    Sep 2018
    Australia
    Pins need to be threaded to allow for the hamfisted.
    Dec 2018
    NY
    Default Wheel problem with RYKERS
    There appears to be a potential issues with the wheels on the Rykers. For those on youtube look up videos by T47 Productions. There are 3 videos by this person who had one front wheel fall off and the other is close to falling off. The dealer and BRP are involved and investigating.
    It appears that for an undetermined reason the wheel alignment pins came loose.
    Please check these on your machine.
    I haven't seen this reported here so it doesn't appear to be widespread.
    -- jim
    Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
    Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
    2022 F3S, special series , Manta Green
    Question #1. Do the Ryker wheels come with pins pressed into the alignment holes? The reason I ask is it looks like on the parts diagram there is a pin in the wheel and I do not find a part # for the alignment pin. If the pins are part of the wheel assembly from the factory then I'm guessing there is a hole size vs. pin size issue. If the drilling of the holes in the wheel is not controlled tightly enough then the pins could either be loose in the wheel, or the interference fit is not sufficient to hold the pin. Or, maybe the holes in the rotor are just a bit too large and allows some rotational movement between the rotor and wheel. If that is the case then it's a BRP problem, not a dealer problem. In a way this could be the same type of problem that has been seen with the RT front drive pulley, i.e., just enough looseness between the pulley and shaft to allow rotational movement.
    I could be wrong but I'm going to speculate the reason for the high torque requirement for the wheel hub is because BRP is counting on the resulting friction force between the wheel and rotor to compensate for slop in the pins and thus prevent rotational movement. Not a good idea, IMO. That approach hasn't prevented the red rust issue with the RT pulleys. Of course, if the wheel nuts were not torqued adequately then it is a dealer problem.
    JC, just a minor FYI. In the list of parts you said will need to be replaced you list hub. From what I see on the parts diagram there is no hub. Instead, it's a short axle that is supported by ball bearings inside the steering knuckle.
    Jan 2009
    austria
    I cannot beleive that the wheel has "fallen off" .. also if the wheels (both ?) where not fixed in the right way, I think the rider would feel that after some seconds ..
    (seems for me more - who pays now for the repair of that story ?)
    Inactive User
    May 2018
    MN
    Any one know what state the 808 mile wheel falling off guy is from?
    This lady having seems to be same issue:
    Lives in The Woodlands, Texas according to FB profile.
    Same issue she said pins were on the ground? I didn't read all comments you may have to scroll to find it.
    https://www.facebook.com/groups/6104...11331/?fref=nf
    Inactive User
    Jan 2019
    Indiana
    The guy who made the videos claims he heard the noise and saw the fender vibrating at least a day before he found the nut loose and continued to ride it without thoroughly checking into it.
    I do think Can Am should have furnished a tool to fit this nut, I will be getting a socket to fit.
    If it was rattling and vibrating it would have been loose enough to turn by hand or shake back and forth, so a little basic diagnostic time would have prevented further damage to the wheel and pins.
    Houston
    Quote Originally Posted by Jsmith8695 View Post
    -- jim
    He has it backwards and so do you. The wheel came loose and that is what worked the rotor pins loose from the wallowing of the wheel on the hub. The pins DO NOT hold the wheel on, they only lock the brake rotor to the wheel for brake force. This really seems to be a simple matter of wheels not being properly affixed to the bike (torqued properly) before he rode it. There is not a design problem or they would all be affected. There are a great many with far more than 800 miles on them. I am sorry for his problems but they are with his dealer for not properly assembling the bike prior to delivery. They now need to fix the carnage and get him back on his bike.
    Mar 2019
    Fla/NJ
    canceling my plans to purchase a Ryker until this problem is resolved! This is not my idea of riding my bike until the wheels fall off. Can-am needs to step up and resolve. It is not the owners responsibility. Dlr should pickup bike and fix or refund purchase price to owner.
    Houston
    Yes that is the part I was referring to. If the french to english translated parts diagram is calling it an axel then so be it. That part is referred to as a hub on other vehicles. I did not look up the part name in the BRP system.
    Jan 2009
    austria
    I hope each dealer knows that here ...
