Results 1 to 23 of 23
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    Default Top cases that don't interfear with the passanger
    Does such beastie's exist yet? Getting on with a back rest would also be nice.
    2019 Rally , Black
    Apr 2015
    Chicago
    Maybe something like this. It would be good to have a higher stop light.
    http://giviusa.com/givi-products/cas...ck-case-detail
    2019 Rally , Black
    Mar 2019
    VA
    Only question would be - would the mounts be happy with more weight that far back given the Max Mount itself is kind of "floating" already. I'm sure it would be fine without a passenger, but with I may start to get concerned (depending on the load in the case of course).
    Just food for thought.
    Jan 2009
    austria
    I use for my 900 this here - black painted lid / backrest / to close with a key !! / and the possibility for LED stoplight on the back / 31 Liter ..
    & just get a U-formed aluminium plate over the max-Mount to make it longer .. very easy solution - should be finished next week ..
    the passenger seat will be a flat GEL-cushion wider than the original ..
    BUT !! seems that we are more a lightly weighty couple
    Jan 2019
    North Carolina
    Quote Originally Posted by chris56 View Post
    Is that a Peugeot Scooter Top Case?
    Also, where would you "just get a U-formed aluminum plate" ?
    2019 900 Rally Edition , Black w/Yellow Panels
    Jan 2009
    austria
    Quote Originally Posted by WilliamTRyker View Post
    the plate is made from a metall company here - yes a"scooter" case - here is another (French) idea to fix a topcase behind the passenger but I`m not shure if that ist strong enough but very "elegant" ..
    Jan 2009
    austria
    fixed on the 4 nuts on the back of the max-mount .. strong enough ???
    Apr 2015
    Chicago
    That is what I have in mind. Does Can AM sell that mount? All I have seen is the top case that replaces the passenger seat.
    2019 Rally , Black
    Sep 2018
    Milwaukee
    Looking for the same thing.
    2019 Ryker Rally , Black and blue
    Jan 2009
    austria
    finally ..a lot of work if you want to have a Girl with you (we ryde since 35 years together..)
    Apr 2015
    Chicago
    I assume you are not going to make her sit on that metal plate
    2019 Rally , Black
    Jan 2009
    austria
    most is finish now .. ready for the first tour !!
    https://www.youtube.com/watch?v=7CBuXwN06J8&t=60s
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    All of this is approaching a Spyder... if you wish to tour two-up that may be a better option?
    Jan 2009
    austria
    Quote Originally Posted by Zoot View Post
    did more tan 62.000 kms on "Spyders" .. now I love the drive-shaft !!! and the CVT gearbox - together thats 100% more for touring here in the Alps than any of the old Modells - the power and the speed is OK for me
    Nov 2018
    Waynesboro, PA
    That is a great job, really looks nice, Chris56.
    2012 RTL , Brown
    Apr 2015
    Chicago
    Did you fashion the back plate where the case sits yourself? I am note a mechanic, so would you post a step by step "how to"? Also, where did you get that great windscreen?
    2019 Rally , Black
    Sep 2018
    Milwaukee
    Agreed on the windshield. Where did you get it?
    Mar 2019
    Fla/NJ
    Yes-----------where did you get that great windscreen?
    Jan 2009
    austria
    First - if you want to install a "better" shield, you have to cut the lid of the glovebox - without that its not possible to fix it in good looking and aerodynamic way & if it is fixed too high looks "crazy" .. the shield is only fixed on the handlebars (5minutes)
    so I cutted it - made a rubber-seal (from a window) and now waiting for a "Lock" system from SHAD - only one key for the glovebax and the side case ..
    I use this smaller PUIG in the moment .. but you could then also use also the wider ones ..
    https://puig.tv/en/tuning-motos/care...ield-upampdown
    the new Aluminium plate for a topcase (mine one is from a peugeot-scooter) is lying "over" the maxmount and makes it 12 Inch "longer it has the "form" of the max-mount and should be fixed with screws to a second plate under the max-mount- I wanted a case with a backrest and a black paintet lid (triple-black-ryky), also some Red Lines on it (maybe with LEDs on the End) - you could use also a SHAD if you want..
    Direkt on the plate with the caseholder is now the seat-pad - as low as possible - she does not want to seat so much higher than me.
    .. ordered now black metal handlebars from a KTM-Bike .. the prices for these adds on where around ..
    Shield ..150,-
    komplete Alu-plate with Seatpad - 400,-
    Topcase with mountplate - 200,-
    https://www.youtube.com/watch?v=7CBuXwN06J8&t=65s
    https://www.sattlerei-wakolbinger.at/motorradsattel/
    Apr 2015
    Chicago
    Thanks for the info, Chris. You certainly are imaginative.
    2019 Rally , Black
    Jan 2009
    austria
    Quote Originally Posted by Rogue Hawk View Post
    used a GS and than an RT the last 10 years, (62.000 kms- most 2up) - I love the drive-shaft and the Design - so I promised my girl that she gets enough space and a "luxury" seat when I ordered this small Ryky last year ..
    Jul 2010
    Las Vegas, NV
    You rock, Chris! I love the imagination and creativity! Now to put some kilometers on it, and let us know! We do love the pictures you take!
    Joe Meyer
    Sep 2018
    Milwaukee
    Great info!
