Results 1 to 5 of 5
    Apr 2013
    Tucson, AZ
    Default Digital speedometer gauge
    Here's a question I haven't seen before. All my digital gauges on my 2015 F3S are set correctly. The date, time, etc. But today when I went to fill up with gas, it changed from MPH and F* to KPH and C*.
    I got it back to F* but it won't go back to MPH. Anyone have this problem and what did you do to fix it? I've held the "set button" and the up arrow like it says in the owners manual, but it won't change!
    2015 F3S , Gray with Orange
    Quote Originally Posted by bubbie View Post
    Did this occur on it's own ???? …. Is it possible you hit the MODE button too many times ???? …. Mike
    Bossier LoUiSiAna
    My ST did same thing few years back (before F3), also changed my radio & rpm display from enabled to disabled & went to trailer mode. Thankfully noticed it at a gas stop & was able to get it back normal. Was fixed with a dash/buds update.
    Apr 2013
    Tucson, AZ
    Blue Knight: All I did was hit the reset on the trip-meter. It had happened at the last fill-up also, but then went back to normal with the "set" and up arrow. I'm thinking maybe I should disconnect the battery and see if that resets it.
    Bfromla: If the battery disconnect doesn't work, I'll probably have to have a buds reset also.
    Apr 2013
    Tucson, AZ
    Thanks everyone! Ron pressed the set button and then instead of just holding the down arrow he kept hitting it and finally it changed back. Now if it will only stay at MPH I'll be happy. Last choice will be just use my Garmin to see my MPH.
