Results 1 to 25 of 27
    Active Member michrick's Avatar
    May 2015
    Liverpool, NY
    Default Magic Mirrors Pros/Cons
    Hi all getting ready to start doing most if not all my service on my 2016 RTL, been doing it on my wife’s 2014 ST for awhile now. The mirror issues is what scares me off but I’m leaning towards the magic mirrors. My question is for the ones who have them are you still happy with them any pros or cons. Thanks much for your words of wisdom, I’ve b the n reading and searching all the forms. Michrick
    2016 RT Limited , White
    Sep 2014
    USA
    There are no CONS..They work Great and have had no issues coming off. If you feel the need add Tethers for added piece of mind.
    Mar 2013
    The only con I found is the cost. After that it's all pro's.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Oct 2011
    Jacksonville,Ar
    I have had mine on for a long time. I have hit a pot hole so hard that i had to get it realigned . and the mirrors never came loose.
    15 rt , yes Black
    Active Member nslowmotion's Avatar
    May 2015
    https://t.me/pump_upp
    Sam, good to hear from you. Will be glad to see you at SOTB
    May 2015
    Liverpool, NY
    Thanks all I’m going to order a set, I understand the cost but if your servicing your Spyder an break a clip your in trouble. The nearest good dealer (reasonable) is 1.5 hours from me. I’m pulling the trigger on these and maybe some gold plugs or dimple plugs for my oil plugs as well. Michrick
    Mar 2015
    forrest above Reno, Nv
    Both the Magic Mirrors and the hex head drain plugs are good mods. Have them both and they make maintance just that much easier.
    Lew L
    2014 RTS , Circuit Yellow
    Oct 2015
    alberta and a.z
    Magic Mirrors are great.
    Northern Kalifornia
    Magic Mirrors PRO's, they work very well, CON's the price. I have both hex head oil plugs and Magic Mirrors (made my own) you can't go wrong with both improvements.
    May 2015
    Liverpool, NY
    Thanks all I’m going to order those items,thanks for the comments and advise. Michrick
    May 2018
    Chateauguay, Qc, Canada
    Deleted.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Vermont
    I have the Magic Mirrors and no problems, Love them!
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Jan 2015
    southern WI
    Totally agree...I was a bit skeptical, so I used a couple steel fishing leaders as tethers....but they haven't ever moved at all. The tethers come in handy for hanging the mirrors during service work though. No regrets here!!
    2016 RTS , Pearl White
    May 2015
    Liverpool, NY
    Thanks all I’m getting them ordered.
    Active Member Grayfox's Avatar
    Nov 2012
    Advance n. c.
    Like mine a lot put tenders on just in case. Up to 85mph passing big trucks no problem.
    INDIANA, USA
    Default Mirrors
    ....'Magic Mirrors' are the game changer....
    ENJOY YOUR LIFE WITH A SPYDER
    Active Member Cleg's Avatar
    Apr 2012
    Queensbury, NY
    I have Blueknight 911 version of magic mirrors that I did install the tether with for my piece of mind. No vibration and after about 8000 miles of riding no concerns. The tether was/is overkill for safety but worth it imho!
    Active Member pwm's Avatar
    May 2013
    Knoxville, TN
    I had them on my 12 RT. They are great but the magnet did mess with my temp gage.
    2017 F3- Limited
    F4 23" Windshield, Ultimate Backrest, Spyder Cuff, SpyderPops Bump Guard, Sena SMH10 Intercom, BajaRon Sway Bar, Baker Cup Holder, RT-622 trailer w/Spyder Pops Bump Guard
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    Quote Originally Posted by Cleg View Post
    Ditto on everything you said
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    GOS member (Girls On Spyders) Spyder_Cowgirl's Avatar
    Bowie, Texas
    Quote Originally Posted by pwm View Post
    All you need to do to correct this is flip the magnets, one at a time, until the gauge starts behaving. Has something to do with the polarity of the magnets in relation to each other and in relation to the gauge. I have installed Magic Mirrors on two RTs (took them off my 2012 and moved them to my 2016) -- never had an issue with temp gauge on either machine (but I was careful to ensure that polarity on all the magnets was the same, I did this using another magnet as shown in Doc Humphreys install video).
    All the best …. Ann
    __________________________________________________ _
    2016 RT Limited -- "Jubilee" (as in Cherries)
    Guardian Bell (gift from spyderowboy)
    ISCI Dual Flag Mount – Tall Poles
    Lamonster Bottle Holder and Spyder Cuff
    Spyderpops Missing Belt Guard
    Spyderpops Bumpskid
    Spyderpops Rear Run / Brake / Turn LEDs
    Spyderpops Mirror LEDs
    Custom Dynamics HMT Brake
    Spyderpops Keep Out The Trash (KOTT) Grills
    Don't Eat Mud / mudflap
    __________________________________________________ __
    Feb 2016
    If magnetism is a problem you can reduce it by 1/3 if you only use two magnets and the stock upper slotted hook. Everything still holds on perfectly.
    2020 RT Limited , Marsala Red
    Active Member BernardD's Avatar
    Mar 2017
    Geneva, Switzerland
    Personally I purchased the magic mirror and was not happy because of the magnetism issue, indeed, and removed them.
    It is a good product and many people are happy but that was not for me.
    However, I found and purchase the Magnetic Mirror Mounts from T r I c l e d. They are really very good, much less fragile than the magic mirror and no magnetism problem at all.
    Ride safe!
    Feb 2012
    Spring City,Utah
    If you are going to replace your drain plugs with hex heads go to Value Accessories and order from them They are high quality, and only 5.95 to 8.95 each. They are made by Big Bike Parts. #BP 5-303 for the 1330.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2015
    Liverpool, NY
    Thanks for the info, michrick
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    I had the wobbly mirror problem after the first time I removed some Tupperware. Lived with vibrating mirrors for a while. Then one time while I had the Tupperware and mirrors off, I removed the little springs from the mirrors, and squeezed the snot out of them with a pair of pliers until they looked cross-legged in my hand. I put them back in place and smacked the mirrors back on. The renewed tension of the springs has held the mirrors rock-solid. Didn't cost me a cent.
