Results 1 to 25 of 39
    Feb 2019
    Liberty Hill, TX
    Default Rear trunk strut replacement
    The strut that holds the trunk open on the rear of my 2010 Spyder RT needs to be replaced. Anyone done this job? I just purchased the bike so this will be my first attempt at repair.
    Quote Originally Posted by robbob View Post
    Yes quite a few actually ….. I have recommended looking in McMaster-Carr for a replacement …… I would check for you but I need the measurements for the ROD and the Barrel, they sell for about $15.00 ….. Mike
    Houston
    Its easy to replace. Remove the passenger seat back and you have full access to both ends.
    This one is available for $44
    https://www.amazon.com/gp/product/B01MDPI3O9
    A genuine BRP one will run you $65. Never found generic ones that would fit, especially at $15. Its a pretty odd ball size made specific for BRP.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Northern Kalifornia
    Sounds like BK911 has it nailed. At that price I'd put in two, one on each side. I did Finless's mod but I have to keep taking it apart from time to time and re-stretch the spring. I heard that you can take your strut into Napa and they can duplicate for you it at a reasonable price.
    I don't know about NAPA @ $15.00 ….. these smaller gas struts at McMaster Carr are really reasonable annnnnnnnnnnnnnnd they come in lots of different pressures ………...MAYBE someone will post the EXACT size of an OEM one ????? ……………There are also sizes for the SEAT STRUT, I'll check my old one that is somewhere in my workshop …..Mike
    May 2013
    Edmonton Alberta, Canada
    I put 2 on mine, great & inexpensive upgrade!
    Travel with a rollbag on the lid and no problems with lid staying open with bag in place!
    2014 RT-Ltd , Cognac
    Feb 2019
    Liberty Hill, TX
    Thanks people. Just what I hoped to hear. After I do the job I'll post where I ended up getting the strut(s), their cost and how it went.
    Robbob
    Oct 2014
    Fort Mill, SC
    Quote Originally Posted by Purple Guy View Post
    Do you have a source name and part number?
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    I replaced mine with the one JC links to above and later added another one to the other side. I suggest you add a fender washer to the ball stud at the bottom. There's enough pressure on the stud that the plastic flange it bolts to will start to bend. If you decide to put one on the other side you can get a ball stud from NAPA with a 10 mm ball except it'll have a 5/16" thread, not 6 mm, but the sizes are close enough to not cause a problem. The top end uses a bushing. Buy one close to the right ID and OD from your hardware store and cut it to the right length.
    Sep 2016
    clark county indiana
    Robbob
    be carful with that riders back rest , those 2 nuts that are on the inside of the back rest will pop out from what I have seen , and read ... just a little bit of pressure when reattaching the back rest to grab the nuts , just to get the bolt started !
    May 2013
    Quote Originally Posted by Grandpot View Post
    I just bought mine from my dealer as I couldn't find a similar size and style in Canada and to order one from the US with the difference in the $$$ and shipping wouldn't have been cheaper.
    Gaz Shock - 708300383
    If you're mounting the second side as well you will need the mounting hardware as well
    Top Mount
    Spacer - 708300384
    Stainless Torx Screw,Nylon Patch,M6 X 30 - 250000398
    Domed Nut M6 - 232361493
    Bottom Mount
    Ball Stud - 250300039
    Hex. Flanged Elastic Nut M8 - 233281414
    Hmmmmmm, have never seen any indication of a problem! There are actually three screws into the backside of the backrest and two at the top edge of the trunk.
    Are you by chance thinking about the two screws that hold the seat in place? Those are problematic.
    Oct 2014
    Fort Mill, SC
    Top Mount
    Spacer - 708300384
    Bottom Mount
    Thank you.
    1998 Honda Valkyrie
    US Navy Veteran
    May 2013
    Sacrament0, CA
    Top Mount
    Spacer - 708300384
    Bottom Mount
    Purple guy has the correct info here.
    Added the second strut on myself (dealer sourced) and it works fine with the trunk rack loaded
    Nov 2018
    Claremore, Ok.
    I am just now installing Passenger Arm Rests. I put Duct Tape over the holes at the way back end so as not to lose the nuts and bolts. Murphy and I are really tight.
    Houston
    Just FYI, BRP got rid of those captured nuts on the back rest for the 2018 model RT.
    Feb 2012
    Spring City,Utah
    there are a couple of threads here somewhere on the subject of the nuts coming off, but I can't find them. Anyway the nuts are glued to the seat back and can pop loose if you put too much pressure on them when screwing them down. They don't need to be super tight, just snug enough to hold the cushion in place.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    I just HAD to take my seat back off to see what you guys are referring to. So they used to be, like my 2014, very securely anchored but not any longer, right? It's things like this why I made the comment in Bob's leaving thread about beginning to feel less relevant. My experience just ain't the same as that of the owners of newer Spyders.
    Active Member SteveandBelinda's Avatar
    Canton, MI
    I replaced mine a couple of years ago, and cost me somewhere between $14-18.00
    I am sure I have the info on one of my posts from then, along with price and where I bought.
    2014 Can Am Spyder RT Limited - Pearl White
    2010 Can Am Spyder RT - Full Moon
    Feb 2012
    Spring City,Utah
    Thanks JC that is a good thing to know
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Active Member Tatonka's Avatar
    Jan 2018
    North Carolina
    Www.canamspyderaccessiries.com sells a little rod type unit similar to how the hood of cars was held open....installs E Z....
    Quote Originally Posted by Tatonka View Post
    How about a direct link? I don't find it. Also, correct the spelling to http://www.canamspyderaccessories.com/!!!!
    Jan 2018
    North Carolina
    Sorry for the typo...if you can figure that out you should find the site....
    May 2018
    Chateauguay, Qc, Canada
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Yeah, I found the site alright. It's the product I can't find!
