Results 1 to 13 of 13
    Inactive User
    Sep 2014
    LOS ANGELES CA
    Default 2010 RSS not starting!
    Hi Guys,
    I had my spyder in the garage for about 2 months, I needed to jump start the battery to get it going. after riding for about half an hr, I Parked it and it would not start. I figured it could be the battery so I Tried to jump it again, but it did not work. So when I turn the ignition to start the bike, the bike resets and asks to press the M button, and then again and again. Could it be the starter is bad? anyone run into this issue?
    Bossier LoUiSiAna
    Pull the battery & have it tested. May need a full charge properly. If is original battery it lasted a long time & needs replacing.
    Sep 2016
    Chillicothe, Oh.
    Have the battery tested. If it has a shorted or dead cell it may not respond to being jumped.
    2015 RT , Black
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    Agree with all the above posts. Battery needs a good saturation charge -- followed by a voltage and load test. I'm thinking you gonna need a new battery.
    Joe
    2023 F3
    Very Active Member GOZFST's Avatar
    Oct 2014
    SD &AZ
    Half an hour ride is not enough to charge the battery. Is the battery original? Like others have said, fully charge the battery and have it load tested.
    Bob S
    Sep 2016
    clark county indiana
    helped a fellow rider last month ( they have r-t modle ) jumped the battery , ran o-kay , but when it came for one more ride it had the same results , reset too mode and no start ! new battery ands they ride happy still today , well when they can ride
    Apr 2017
    North Central Florida
    Also could be a loose connection at the battery.
    But most likely the battery itself.
    Inactive User
    Sep 2014
    LOS ANGELES CA
    THANKS YALL!
    Bossier LoUiSiAna
    Quote Originally Posted by 818Zee View Post
    THANKS YALL!
    This means is fixed & all is good again?
    Inactive User
    Sep 2014
    LOS ANGELES CA
    Actually not really, I dont know which battery I should get. Any suggestions?
    Bossier LoUiSiAna
    Most have reported positives about Yusa. Few have gone for the Pricy but lighter Li-Poly. It's all up to you, how many farkles are you going to power when the bike is not running .
    Know Batteries +bulbs often offers discounts for online orders & will have one charged & ready when you pick it up.
    Sep 2016
    bought this one in my avatar ! used , had the guys who was selling her , put in a yuasa battery ( they had mentioned they put a new one in when they took in the cycle , and it was not starting on command , had too jump start ... with the yuasa battery and a battery maintainer , no problems at all : battery maintainer has led lights , let me know when it is time too plug it in too charge ! )
