Results 1 to 8 of 8
Thread: Un oh, no start
    Active Member Y-me's Avatar
    Feb 2011
    NY
    Default Un oh, no start
    Hi all,
    2013 RT SE5.
    Turning the key boots up the display with no drama.
    Pressing mode shows the usual screen making ready to start and SE5 is in neutral.
    Pressing start and nothing.
    No codes.
    Pressing on the brake makes no difference.
    The battery seems charged.
    Looking a relays and fuses everything looks okay.
    When pressing the start button the relay can be heard clicking over.
    Re-seated number 2 relay anyway and no change.
    Sensor or starter?
    Thanks,
    Y
    Default Bummer.....
    Battery needs help. Profile says 2010 RSS post has 2013 RT so no idea of the age on the battery or how long since you last started her up. Battery needs over 12V to start those machines. A jump start would tell if it is low and needs a charge and a load test would let you know you need a new battery.
    Oct 2017
    Las Vegas, Nevada
    Perhaps a stupid question, but you didn't say and thus I have to ask: Are you sure the "Engine Stop" switch a/k/a "kill switch" (red switch on the right handlebar) is set to the "run" position? As I recall if it's not in the "run" position you'd probably have these symptoms and it's also easy to forget about.
    2017 RTS , Blue
    Bossier LoUiSiAna
    Quote Originally Posted by johnsimion View Post
    happens all too often
    Sep 2016
    clark county indiana
    it sounds like the weak battery deal , it happens a lot when the temp ,suddenly drops and it is colder outside , ( although your cycle is inside ) seems to know when it is time too fail ... new battery is next step if the jump start idea from above post turns the cycle over ...
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    Check the battery voltage and a load test would be what I would check. It could rule out or definitely point to the battery.
    Joe
    2023 F3
    Jul 2015
    Dorr, michigan
    I agree, have done it myself a few times in the spring after it setting all winter.
    You look at it and say "whats wrong with this stupid thing", then realize you are whats wrong. Just a simple brain fart.
    2020 RT Limited , Petrol Blue
    Jul 2018
    Long Island NY
    That Engine Kill switch got me a couple times. Detailed my Spyder the night before a charity ride. Next day my boy and I suit up, hop on...no start. 5 min of panic, then realized I must have hit the kill switch while detailing. Lol. But the worst was when I first got my Spyder, took my son for his first ride. We are sitting at major intersection waiting for light to turn green. It turned green, hit the kill switch by accident, took a minute to figure out how to start. That was quite embarrassing! But luckily the cars behind me didn’t start honking or anything. Dang kill switch...
    Good luck, hope its just your battery.
    2018 RT Limited , Metallic Champagne
Tags for this Thread
