Results 1 to 11 of 11
    Indy
    Question Accessory Mode on 2018 RT
    I've looked through the owners manual several times but could not find the page(s) that denote how to activate the accessory mode, is there one or has that been removed?
    Thanks any help appreciated.
    May 2013
    Edmonton Alberta, Canada
    Okay, I'll bite. What's an accessory mode??
    2014 RT-Ltd , Cognac
    Sep 2014
    USA
    You mean the one where you hold the eco button while turning off the key switch?
    May 2017
    Mesa, Arid-Zone-A
    I think what he probably is looking for is the Mode that plays accessories thru the audio system. On my 2014 I can switch between FM, AM, and Accessory. I have my Sirius radio plugged in to the Accessory port in the rear boot. Don't know if the 2018 has the capability for Acc, but do know they did eliminate AM radio.
    Semper Fi
    Mar 2018
    Oregon
    Here is a video that shows you a little bit about the system: https://youtu.be/ZUKsBQ8n664.
    I'm also adding an image with an arrow that shows which setting to choose. It's called AUX
    Hope this helps!
    SPYDERGAL
    Aug 2018
    north wis
    If you mean play the radio or mess with the info system without burning gas just hit the kill switch and leave the key on.
    Aug 2013
    SF Bay Area
    For those that have never had a Goldwing, the Acc mode is where you turn the key one stop to get the radio to come on and if you want to start the bike you turn the key further to the second stop. Spyder's don't have that and I read where you hold the kill switch down (or is it the emergency button?) when turning the key off and the radio will say on. Will have to try the kill switch trick.
    2021 F3 Ltd , Magna Red
    Indy
    Precisely, on my wifes F3T I press the mode button after turning the key off and it plays the radio, on my 2018 with the new dash that seems to no longer be available.
    Aug 2018
    north wis
    Key on fires up dash functions,kill switch off leaves fuel pump etc. off.You can hear pump start when kill is turned on.
    Indy
    Quote Originally Posted by woods View Post
    Only problem with this methodology is that various external lights are on i.e. tail, fender lights etc, on other models only the console is active. Its my guess that with this new 2018 dash it was likely removed, too bad because if you were using BRP connect it would not have to re-initialize when you restarted.
    Aug 2019
    Metcalfe, ON
    Unhappy
    Agree - appears to not be there on my 2018 Spyder either. Too bad - the Acc mode on my Goldwing allowed me to play the radio or iPhone tunes without draining the battery with headlights, etc.
