BEST WAY TO GET TO THE AIRBOX
NOT TO SURE THE WAY TO GET TO THE AIRBOX.. AND CHANGE THE AIRFILTER...
remove panels
Remove the two side panels and the top panel in front of the seat.
Then 8 clips and 2 hoses come off to allow the air box top to make a very tight slide to the right and you'll see the air filter.
Happy owner of Silver PE #1232
All The Gear All The Time - ATGATT
Gulf Coast SpyderRyders
Did I miss one? I only had one hose, on the right front just above the air intakes.
2008 GS SE5 in 2008
2010 RT SM5 in 2011
GOOD DEAL.. THANKS FOR THE INFO
No, you're right. The left side hose is the breather and is connected to the box, not the lid.
Whew! Thanks! I looked into the filter box last oil change. Only oil seemed to be a film collected in the top of the lower half. Nothing under the filer, just around the cover edges. So, I cleaned the top, the cover insides, etc., and we'll see how long it takes to get oil dropping on right side again.
2008 GS SE5 in 2008
2010 RT SM5 in 2011
