Undressed Ryker Photos
Thought I'd post some pictures of an undressed Ryker that was on display at the dealer conference. You can see the belt cover pretty well in a couple of the photos, and how minimalist it really is. Very simple, very clever design
more undressed
more
![Quote](images/misc/quote_icon.png) Originally Posted by Triumphcycleman
Thanks .....
Great shots... and there you have it...bare cbones...
It appears from these shots that the engine is installed longitudinally, is that correct?
No belt = no belt cover! Driveshaft cover only.
Naked Ryker
Where does the gas tank go and where is the "gas cap" access?
Happy owner of 2014 White RTS - SE6 ![Big Grin](images/smilies/biggrin.png)
engine configuration
Yes. The crank is aligned with the chassis, the CVT drive clutch runs straight off of it (see pictures from the rear) so there isn't much "loss", it goes thru the belt to the driven clutch pulley, which powers a very simple forward/reverse gear box. There is a lever on the left to select either F or R, and above, near your left knee, is a lever to lock it in "park". Of course the output shift of the gearbox turns the driveshaft to the rear differential. As for the 600 vs 900, it is simply a matter of 2 cylinders or 3.
![Quote](images/misc/quote_icon.png) Originally Posted by ottawa-rider
There is no belt, it is shaft driven
Cruzr Joe
![Quote](images/misc/quote_icon.png) Originally Posted by Boilermaker
No belt = no belt cover! Driveshaft cover only. ![thumbup](images/smilies/thumbup.gif)
I think he meant the cover for the CVT belt he mentioned in another post about maintenance. The big black plastic bit in photo 3 that looks like it's off the back of a washing machine!!
| 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
Does the lever have to be held in the reverse position is does it lock into reverse? I'm interested because I have a prosthetic left leg (full length) so couldn't operate it with my left foot, but I could reach it to move it into place with my hand I imagine.
![Quote](images/misc/quote_icon.png) Originally Posted by Cruzr Joe
Cruzr Joe
Shaft driven... with a CVT transmission!
(That IS belt-driven!)
Cruzr Joe
There is a belt from the drive clutch to the driven clutch (CVT Transmission). The driven clutch is connected to the gear case which drives the drive shaft to the rear wheel. See picture on this page: https://can-am.brp.com/on-road/exper...hnologies.html
I'm hoping the Silver Grill (below Radiator) and 2 side grills near wheels will be add ons for the Normal Version because they really help the appearance No matter what color you choose. My dealer says I'm crazy to trade in the F3 BUT he got to the meeting Late and NEVER drove one?
Sea Doo GTI-SE 90 Jet Ski!!
Does that whole upper assembly pivot up/forwards on the production model? That would greatly enhance access to the engine bay.
Wonder if some customizer will come up with a sleek swoopy racer (non-tractor) looking body panels, that would open up a whole new industry. More like their Sea Doo and Ski Doo lines.
JLohPhotos
![](signaturepics/sigpic10708_2.gif)
https://youtu.be/A1c7cU9NSeU
I Know the Basics of CVT but this Video Gave me a Pretty good idea of what changing a belt would entail . I Love the Ryker concept More every day!
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
![](signaturepics/sigpic20397_1.gif)
And what's with no lug nuts??? Do the wheels slide onto a splined axle and held on with a single nut and safety pin?
BajaRon Sway Bar
Foam Grips
Shorty antenna
![Quote](images/misc/quote_icon.png) Originally Posted by Bob Denman
You're not actually wrong... ![Big Grin](images/smilies/biggrin.png)
The final drive is by shaft
The belt operated transmission is where things get a little bit "wonky"...
Shaft drive, and belt transmission!
(Are you missing a strap for one of the hard saddlebags?)
Early information stated that there is only ONE saddlebag due to the shaft guard on the left side. We joked about it in an early thread--but I don't know if the issue was totally resolved.
![](signaturepics/sigpic4721_5.gif)
Looks like $10,000 to me!! May be fun to yank around the hood, but you get what you pay for!!
Rear fender differences
Just a thought......
Am I the only one who noticed that the Rally model has only a small "splash" fender over the rear tire and the regular one has a full fender?
Seems like the off road model would just make a mess of the underside with the shorter fender.
